TL-design box for W5-1611sa
Old 15th April 2013, 08:35 PM   #31
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Originally Posted by chazdrumzalot View Post
...And here it is. 1/5 taper, 43hz tuning. Very compact albeit deep. A SUPER XL desktop TL, as it were.
so let's see what happens if we simply half the depth (and thus half the cross section of the line incl port):
(also the amount of stuffing half)
Old 16th April 2013, 12:25 AM   #32
chazdrumzalot is offline chazdrumzalot  United States
Henkjan, many thanks to you for running those simulations. The 5db dip at 300hz seems too deep and broad to make this a really good design; will changing the taper of the TL have any significant effect on that? If not, maybe I'll still give this a try just to compare it to my DBR design.
Then again, what do I know?
Old 16th April 2013, 02:20 PM   #33
Henkjan's Avatar
1st: in real life, these dips will be less than simulated.
if the taper is increased, then the line length will decrease (for a given tuning) and the frequency of the dip increase, increasing the effectiveness of the stuffing in eliminating the dip. lower tuning will have an effect in the same direction. I'll do some additional runs later in the week.
Old 16th April 2013, 04:00 PM   #34
Perhaps 43hz is a little too ambitious for a tapered line. Maybe a higher tuning is the way to go, say 48 or 50hz?
By the way, when I play around with the worksheets (in this case, the W5 driver with 50hz tuning in various iterations) I tend to get cabinets that are very short and deep, sometimes deeper than they are tall. changing the taper doesn't seem to do much. Am I doing something wrong?
Old 16th April 2013, 06:08 PM   #35
DYNABLASTERTUNERS is offline DYNABLASTERTUNERS  Serbia
DYNABLASTERTUNERS's Avatar
Here is a superb Enclosure for CHP and Alpair7 etc.
Die "Point Seventy" mit dem CHP70 goes "Fuzzy" - DIY-HIFI-Forum
http://www.diy-hifi-forum.eu/forum/s...ead.php?t=6360
Old 17th April 2013, 04:24 AM   #36
Yes, you've both made good points; that dip is probably not so bad. Maybe I'll go ahead and try this design without any adjustments.
Old 17th April 2013, 03:13 PM   #37
Originally Posted by DYNABLASTERTUNERS View Post
I made a mistake, don't know why I have posted that in this thread Can mods please transfer this to some thread with CHP or Alpair?
Old 17th April 2013, 03:23 PM   #38
That's funny, I thought you posted it to demonstrate that there are other good enclosure designs with midrange dips.
Old 18th April 2013, 07:35 AM   #39
That dip is irelevant
Old 3rd July 2013, 11:20 AM   #40
Goodlagger is offline Goodlagger  Australia
Default Gonna have a crack at the TABAQ
I've got my w5 TBs and my front and sides cut didn't have enough off cut for the top and bottoms will need another trip to the hardware store
My local only had 16 mm MDF so I made the necessary adjustments to keep the same internal dimensions
Question will it effect the boxes tuning if I rounded the port opening and front edges asthteticly I think it would be better
What about stuffing it mentioned it need some in the top third what would be best to use
TL-design box for W5-1611saHide this!Advertise here!
W5-1611sa Jeb-D. Full Range 75 14th February 2013 06:14 PM
Tang Band w5-1611sa question.. Dxvideo Multi-Way 9 2nd January 2013 02:51 AM
W5-1611SA - not underhung? capslock Full Range 6 26th November 2012 10:24 AM
W5-1611sa same64 Full Range 40 22nd May 2012 10:16 AM
Anyone tried W5-1611SA in a sealed box? Zoodle Full Range 12 15th April 2010 03:48 AM
