Old 13th January 2013, 08:44 AM   #21
Scottmoose's Avatar
Originally Posted by Gost22 View Post
Can you give a general explanation of what it means Sd-in cm^2 on speakers, or what is the area?
Cross sectional area of the cone.
I need a website where I can find the full range speakers from 5 " or 5 1/2". Addresses in Europe where they are available.
thank you on all!
A few minutes doing a search via Google or any of the other engines will reveal a few. Spectrum Audio, Europe Audio, Blue Planet Acoustic, Lautsprecher etc. all stock a wide variety of products. Come on, be a bit proactive.
Old 13th January 2013, 12:43 PM   #22
Gost22 is offline Gost22  Bolivia
Gost22's Avatar
[QUOTE=Scottmoose;3323528]Cross sectional area of the cone.
I apologize much is clear for nothing , that the sectional area of the cone?
Thank you!
Old 13th January 2013, 12:50 PM   #23
Gost22's Avatar
Hi guys!
Anyway I chose the full range (50Hz...16kHz) speaker Visaton BG20 (27 EUR for piece), so please recommend a project (design) box for this speaker, percent for this full range speaker W5-1611saf in Europe seeking 85 Eur for piece!!?.
Cheers!
Old 13th January 2013, 12:53 PM   #24
ODougbo is offline ODougbo  United States
I see no mention of the W5 1611SAF
Tang Band W5-1611SAF 5" Full Range Speaker 264-918
I have two pairs here, nice little speaker; lacks a bit on the high end.
Old 13th January 2013, 03:03 PM   #25
FWIW, I'm working on a folded TL for the W5 using Henkjan's TL spreadsheets. The tuning will be the same as the W5 Tabaq, under the assumption that the performance will be comparable. I'm motivated by the desire for a shorter, more diminutive cabinet.
Then again, what do I know?
Old 13th January 2013, 08:16 PM   #26
...And here it is. 1/5 taper, 43hz tuning. Very compact albeit deep. A SUPER XL desktop TL, as it were.
Old 13th January 2013, 09:38 PM   #27
Scottmoose's Avatar
Thank you!
It is the surface area of the cone. I'm afraid I can't think of a way to express it more simply. All two dimensional shapes have a surface area. This is given in terms of the square of a given unit. For loudspeaker drivers, this is usually square inches, square centimetres or square metres, abbreviated as 'Sd.'
Old 13th January 2013, 09:59 PM   #28
grindstone's Avatar
Nice pipe. Hey Chaz -- will these be floor units like your OB design was? Just thinking maybe you might want to tilt the baffle back so that you get some HF when seated a ways away. That's one mistake I made when I made a small floor box. FWIW.
Old 13th January 2013, 10:35 PM   #29
Good point, and yes, I'm thinking of at least propping the speakers up from the front. It would look really nice to build them with a slanted baffle though.
Old 15th April 2013, 08:30 PM   #30
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
so here is the response of this:
W5-1611sa Jeb-D. Full Range 75 14th February 2013 06:14 PM
Tang Band w5-1611sa question.. Dxvideo Multi-Way 9 2nd January 2013 02:51 AM
W5-1611SA - not underhung? capslock Full Range 6 26th November 2012 10:24 AM
W5-1611sa same64 Full Range 40 22nd May 2012 10:16 AM
Anyone tried W5-1611SA in a sealed box? Zoodle Full Range 12 15th April 2010 03:48 AM
Copyright ©1999-2013 diyAudio
