Wild Burro Betsy OB Build
Old 1st January 2013, 11:01 AM   #21
zimmer64 is offline zimmer64  Switzerland
zimmer64's Avatar
Default JE labs baffle?
Happy New Year to all of you.
I have also orderd a pair of Betsy's and wait (impatiently ) for their arrival. Got inspired by Fleawatt's posting in the Bottlehead forum.
Here is my question: Has anyone tried a JE labs baffle with the Betsy's? Why or why not?
Thanks for your opinions.
Michael
Old 1st January 2013, 03:20 PM   #22
danvprod is offline danvprod
danvprod's Avatar
Michael
Here is one thread on it:
JE Labs open baffle advice?
Paul recommends it as well:
Wild Burro Audio Labs - Fullrange Speakers - The Betsy & Betsy-K Drivers
BTW my drivers get here tomorrow!!
Has anyone have any suggestions about dampening the back of the baffles? Would just adhesive cork board work, or should I do something else?
Dan
Old 1st January 2013, 10:34 PM   #23
GM is offline GM  United States
GM's Avatar
From just listening tests long ago, the various cork products I tried were all too hard to be of any use beyond decorative, so switched to thick felt or jute carpet padding, which worked well, but I still preferred the old fashioned way of loosely fastening an acoustic fiberglass insulation 'blanket' over the rear of the driver[s] and covered with a double knit or similar cloth to contain it to make it act similar to a very low Qt [lossy] box.
GM
edit: the driver[s] need to be covered with cheesecloth before adding the insulation.
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 2nd January 2013, 02:45 PM   #24
danvprod's Avatar
Thanks, GM for the reco. I'm going to listen first and then treat from there, if needed.
Dan
Old 6th January 2013, 01:31 PM   #25
danvprod's Avatar
OK -- project update.
Baffles are built and BetsyKs are installed. DIY Cat5e speaker cables built. I'm only using 2 of the leads in the Cat 5 per side to add a bit of resistance to tame the HF response.
Amplifier is a Class D TPA3122 based on @cervelorider's reco. I have it powered by a 12v SLA battery. It sounds amazing!
They speakers sound really good on most things -- but I've noticed that on certain instruments, mainly solo piano this happens (listen to the distortion/resonance in the last few seconds of this video):
That little amp can certainly drive them to a perfect listening volume (I've been listening between 25-33% volume on the pot) -- and I love the battery powered setup (right now I am either using my iPad/iPhone as a source or my turntable. The turntable setup rocks, perfect match for this amp and speakers).
I did end up swapping out the piano hinges for a black duct tape/regular hinge solution, as I thought that this was causing the resonance. In retrospect, I would not recommend the piano hinges at all for a project like this. They are too expensive and way too many screws.
To cure the resonance/distortion issue with this driver, I tried the following:
1) Removed both piano hinges (as I thought they might be rattling).
2) Taped up hinges first and then installed new hinges (2 per side, 2" medium hinge).
3) Switched drivers on baffles. (left for right) -- to see if it was the baffle or the speaker.
4) No matter what I did this is the distortion I get. I checked the interconnects, the speaker terminals the wires. The VC is not rubbing. It seems to only manifest itself on piano, but only on this speaker (the other speaker does not have this distortion. It's the oddest thing.
I am open to any ideas or thoughts you may have, especially since only one speaker is doing on it, no matter what baffle I install it on.
Old 6th January 2013, 02:08 PM   #26
cervelorider is offline cervelorider  United States
cervelorider's Avatar
It appears it is an issue with the driver. I'm sure Paul will send you a replacement.
Old 6th January 2013, 04:25 PM   #27
Oh yeah.... and your system looks and sounds awesome.
Enjoy the music!
Old 6th January 2013, 07:35 PM   #28
zimmer64's Avatar
Just to factor everything else out, I would also try another amp. Not that I don't trust the little class D amp (built one myself :-)), but I would recommend to make sure.
Best of luck and keep us posted.
Michael
_______________________
Michael's Project Page
Old 6th January 2013, 08:00 PM   #29
danvprod's Avatar
Here are some impedance traces of the drivers. This is through my Cat5 speaker cable. Measured with Impedance sweep module of AudioTools on my iPad with an iAudioInterface2.
Fs is 51.59 and 54.96 vs published 49.959. Re is 4.50 and 5.24 vs. published 5.7
Old 6th January 2013, 08:02 PM   #30
He switched the driver from the left side to the right side and the distortion issue followed the driver. If it were the amp, it would be safe to say that the distortion would be channel specific. Right or left. Am I missing something?
Michael
Wild Burro Betsy OB BuildHide this!Advertise here!
Visaton B200 Vs. Wild Burro Betsy... Manolo47 Full Range 11 3rd April 2013 08:11 PM
For Sale: Wild Burro Betsy Drivers - Pair norman bates Swap Meet 3 13th October 2012 09:18 AM
Wild Burro Audio Betsy OB pair bigaudioscotto Swap Meet 1 20th December 2011 10:10 AM
Wild Burro Betsy with Plugs. bigaudioscotto Full Range 5 10th October 2011 09:16 PM
Wild Burro Betsy unopened sale. bigaudioscotto Swap Meet 1 6th November 2010 08:45 PM
