#21 |
Re the wonders of a 'giant Cornu spiral... [with] lots of output up into 500Hz':
Output above about 300Hz from a back load = chronic group delay which is very audible for most people. Assuming, for e.g., a 6ft flare path length, then working on average SoS of 1.13ft / ms you've got a delay of 5.3ms up in the 500Hz BW: well above the 3.2ms audibility threshold for that frequency established by Blauert and Laws. A lower acoustic XO is needed, but without some help from the amp, Eq or whatever, the driver will need a short front horn to fill in the region between its mass corner and the practical upper corner frequency of the horn. I wouldn't advise taking any back load much beyond ~300Hz. |
#22 |
Sorry to interrupt you gentlemen
, but can someone tell me if I'm wrong with my results (using the spreadsheet from Zillasspeak) to design a BIB (using the datas from the AN webpage?The spec. : Driver : Audio Nirvana Super 8 Cast Frame sensit. : 97.3 db equivalent diaghram radius : 88 mm equivalent mass : 10.023 magnet weight : 1400 g net weight : 3690 g Fs : 44.63 Re : 7.2 Mms : 11.748 g BL : 11.84 TM Qts : 0.162 Qms : 3.836 Qes : 0.169 Vas : 66.495 ltre Xmax : 1.0 mm no : 3.379 % My results : Line length : 150,85 Zdriver : 32,73 Sm-terminus area : 110,60 Depth (internal) : 12,51 Width (int.) 8,84 Nominal Height- L/2 : 75,42 Thanks again ! |
#23 | |
If the factory specs are 'in doubt' which do you use to design? My measurements or the factory set? sorry to OP for clogging up his thread. |
#24 | |
#25 | |
Note that based on the published specs for Sd [~243.849 cm^2], Mms, BL, Fs, then Vas = ~91.785 L. If there's no measurements, then use a ~0.4 Qts and if the amp's output impedance isn't high enough [DF = ~1], then some form of additional series resistance may be required to flatten out the speakers in room response. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#26 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#27 |
I would go with a subwoofer instead.
#28 |
BIB is not really horn, both like classic TQWP....
#29 |
frugal-phile(tm)
Both BIB & classic TQWP = Voigt are classified as tapped horns.
dave
#30 |
Indeed. The BIB is a simple tapped corner horn. If it expands toward the terminus, some form of 1/2 wave resonant behaviour is present, ergo, it's a horn. As it happens, GM informed me some years ago that originally 'TQWT' was used in the opposite sense of how it is often employed these days, i.e. it was a pipe that narrowed toward the terminus. Although I suspect he & I are the only people here who continue to use that definition.
| effects of midrange enclosure qts | slr 5000 | Multi-Way | 6 | 20th February 2012 07:41 AM |
| Possible use of a very low QTS driver? | giralfino | Multi-Way | 7 | 10th January 2011 04:12 PM |
| what sounds best . . . Low Qts in small cab or higher Qts in bigger cab | mikelm | Subwoofers | 18 | 15th July 2009 10:46 AM |
| High Qts woofer enclosure | pelanj | Multi-Way | 3 | 3rd December 2008 08:22 AM |
| Need 8" sub - low Qts, low Fs??? | geolemon | Subwoofers | 14 | 19th June 2005 12:38 AM |
