#61 | |
I play them as low as they go. I'm not sure about the numbers, but will try to make some measurements this weekend. |
#62 | |
I might be able to get around 0.75litres at a guess, I haven't been able to measure properly yet but will be around that. I will be able to mount them directly on axis to the driver, so with some luck this will take advantage of the highs, as much as the driver can offer. I am happy to cross them around 350hz ideally, I'd prefer low but this won't be possible in the small enclosure. This is modeled in a 0.75 liter sealed enclosure with some stuffing, as you can see it's -1.7dB at 353hz ![]() Any measurements you might have would be fantastic! This is not the only speaker I am considering, also the Fountek FR88EX and Tang Band W3-315E |
#63 |
A guy won the Norwegian championship (audio quality) using the w3-871 (dash mounted) and the w6-1139 in doors. Don't remember the amp or xo but I think it was around 150 Hz...
| Help with Tang Band W3-1364SA | droidsocket | Full Range | 1 | 1st July 2010 02:34 PM |
| Tang Band W3-593SF vs. Tang Band W3-926SD | Zaputh | Full Range | 17 | 5th June 2009 11:37 PM |
| I want your tang band w3-871s !!!!!!! | norman bates | Full Range | 0 | 15th September 2008 06:43 AM |
| Tang-band 2-way (W3+W8) | haffe | Multi-Way | 10 | 31st January 2007 11:11 PM |
| Tang Band W3-315SC, anyone? | pristex | Full Range | 1 | 30th December 2004 04:47 PM |
