Tang Band W3-1878 - Page 6 - diyAudio
Old 24th December 2012, 11:45 AM   #51
RK1 is offline RK1
Merry Christmas and Happy New Year
Old 24th December 2012, 01:56 PM   #52
aarvin2 is offline aarvin2  Mauritius
Originally Posted by RK1 View Post
I'm not sure in what conditions was made.
Very helpful ... NOT
Old 15th January 2013, 09:53 PM   #53
HI guys... any new feedback on this topic please ?
Old 23rd January 2013, 12:46 AM   #54
Indeed! I am looking to use the W3-1878 driver with no tweeter, how would this go directly on axis? I've been modelling it in a small sealed enclosure ~0.75 litres and the results seem OK. No option of using a tweeter, I am looking for a dedicated wideband which can play down to 300hz - 500hz and up to 20khz without the need of a tweeter.
I have considered the W3-315E which is also a good option, but the sensitivity is lower and the xmax is much smaller, which I think could be bad for my situation.
Thanks.
Old 28th January 2013, 12:22 PM   #55
holtet is offline holtet  Norway
I just finished my TABAQ pair with this driver this weekend. And so far I'm amazed! They sound really nice with a lot of different music. Some things, like Led Zeppelin sound a bit harsh and thin. But I still haven't had enough time to experiment with placement, electronics etc.
They play music in a quite "laidback" way, which also makes them very relaxing and nice to listen to. Placed close to the wall in a small room (6-7m2) like in the attached picture, the bass is amazing and perspective quite nice. They also play more than loud enough for normal listening (IMO).
In the middle of a larger room (15-20m2), the bass is a bit lacking for some types of music, but then the perspective and realism becomes really amazing. Close to the wall in this room also works nicely with moderate sound levels, and the perspective is nice even with as much as 3m between them.
I run them fullrange without any tweeters, using only the baffle-step filter
as suggested in the tabaq design document.
If there is any interest in more details, please ask!
Old 28th January 2013, 12:36 PM   #56
Good job mate!!
Could you please tell me about the sound of the mids and highs ... and if you honestly need a tweeter to hear the details around 10 KHz and more? Is everything present, clear fast and detailed up there ?
How low did you get toll now ?
Old 28th January 2013, 01:01 PM   #57
Good job mate!!
Thanks!
The mids are really nice, I think. Especially when placed 1-1.5 meters from walls, you really hear the details (as with most speakers, they sound better with some air around them.
I haven't measured either them, or my hearing, but I didn't miss any detail up high either. Of course they need to be placed directly towards you because the treble is quite directive, which means I have placed them facing directly towards the listening position and also tilted a bit upwards.
My main speakers have scanspeak 9500 softdomes, which of course are softer and more detailed, but then again the price is a bit different... And so far I would say I'd rather have the highs of the 1878 than a cheap or badly integrated tweeter.
And if I feel the need to complicate things, I think I'd make a subwoofer rather than adding a tweeter
I'm sorry, I didn't understand this question?
Old 28th January 2013, 01:14 PM   #58
Thanks!
thank you for your patience and explanations Is it way worse than the scanspeak ? how much % would you rate it ?
Sorry I made a typoe, I mean, how low does the system go ?
Old 29th January 2013, 05:51 AM   #59
I'm not sure I would say "worse", but rather different and difficult to compare directly. Maybe not as detailed, but I'm not really sure about that either. I didn't have time to A/B listen, but maybe I will before the weekend.
I also haven't had time for measurement. I'm quite amazed on how low bass you can hear. You get all low-end information in most music. But of course you can't feel it, and you must keep in mind the drivers are the size of large headphones
Old 29th January 2013, 11:28 AM   #60
Very good feedback here
I am planning to use the W3-1878 in small sealed enclosures on the dashboard of my car. I am hoping I will not miss having a tweeter, I hope these will provide all of the high end detail. They will be mounted directly on axis to the driver, and being in a car there are a lot of reflective surfaces to worry about, so reflections are difficult to deal with.
How low are you playing these?
Thanks!
Help with Tang Band W3-1364SA droidsocket Full Range 1 1st July 2010 02:34 PM
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
I want your tang band w3-871s !!!!!!! norman bates Full Range 0 15th September 2008 06:43 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
Tang Band W3-315SC, anyone? pristex Full Range 1 30th December 2004 04:47 PM
Copyright 1999-2017 diyAudio
