Tang Band W3-1878
Tang Band W3-1878
Old 20th December 2012, 08:56 PM   #41
cross reference is offline cross reference  United States
Originally Posted by aarvin2 View Post
Price is not a problem actually
Have you experienced both the w3-1878 and the w3-315e ??
By the way frequency graphs only tell 1/8 of the whole story.
The W3-1878 has great Qts, better construction materials, good BL etc
You should looking into the Newer Fostex FF 85wk 3 inch fullrange drivers. Nothing that I have heard can touch them at any price point! CR
Old 21st December 2012, 07:35 AM   #42
aarvin2 is offline aarvin2  Mauritius
The thing is we all can read specs but it's HEARING the speakers which finally counts, so this is why i'm looking for people having an experience with those speakers ... who can describe(hopefully) how they sound.
Old 21st December 2012, 08:29 AM   #43
mattlong8 is offline mattlong8  United States
mattlong8's Avatar
Some would argue that distortion, phase, impedance, and amplitude (vs frequency) measurements is what counts. At least for a designer. But ultimately it has to sound good yes, however the ear can't provide an absolute reference nor can it point you in the right direction when optimizing.
I've spent far too much time tuning systems via trial and error. It started making me crazy so now I measure.
-Matt
Old 21st December 2012, 09:12 AM   #44
-Matt
Hi Matt, unfortunately the measurements don't tell 100% of the story. For example a speaker might produce certain frequencies while doing frequency sweeping but when playing all the frequencies at the same time, some frequencies might disappear due to I don't really know what.
I tried it in the studio, testing a small 2" speaker with no enclosure. I soloed a small high frequency band which targeted a nasty sibilance and the sibilance could clearly be heard.... but when the whole song was playing altogether, the speaker could not produce the sibilance.
This is why I think that specs can tell the story to some extent but finally amp, DAC, speaker designers have to ultimately use expert ears to fine tune their products.
Old 21st December 2012, 11:36 PM   #45
Melo theory is offline Melo theory  United States
Melo theory's Avatar
This could be reason why a resonance may not show up with pink or white noise.
Intermodulation-distortion and Doppler-distortion ??
The offending bandwidth could be hidden with phase distortion.
But 1 driver will not be better than another in this regard by a listening test. all full rangers with suffer from IMD when trying to cover too much bandwidth.
As far as choosing a driver, if the HD profile is clean and the driver breakup
is tame or high enough not to notice (above about 12 kHz) then it's a good choice.
I wish Mark K. did a HD measurement of the TB driver....it would tell us a lot more.
I LIKE YOU
Old 23rd December 2012, 11:40 AM   #46
RK1 is offline RK1
Originally Posted by xrk971 View Post
RK
Can you please share your measurements?
I found the measurements of this site (I'm not sure whether they will need you to something)
Have a nice day
RK
Old 23rd December 2012, 12:43 PM   #47
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Tang Band W3-1878
Rk,
I only see an image of driver in unusual flower shaped cabinet. Where are your measurements again?
Thanks.
Old 23rd December 2012, 07:40 PM   #48
RK1 is offline RK1
I found only this measure. I'm not sure in what conditions was made.
If I find a moment of time will do you measure.
Have a nice day
RK
Old 23rd December 2012, 07:45 PM   #49
RK1 is offline RK1
for compare - seas exotic
Old 23rd December 2012, 10:18 PM   #50
Geeze! RK1 is a high roller!
I LIKE YOU
Tang Band W3-1878Hide this!Advertise here!
Help with Tang Band W3-1364SA droidsocket Full Range 1 1st July 2010 02:34 PM
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
I want your tang band w3-871s !!!!!!! norman bates Full Range 0 15th September 2008 06:43 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
Tang Band W3-315SC, anyone? pristex Full Range 1 30th December 2004 04:47 PM
