Ever think of building a Cornu Spiral horn? Now you can! - Page 73 - diyAudio
Old 30th March 2013, 01:40 AM   #721
xrk971 is offline xrk971  United States
xrk971's Avatar
Fran,
Do you have listening impressions yet for your all wood Cornu's?
X
Old 30th March 2013, 12:02 PM   #722
Hi X!
Not yet I ordered the driver several days ago, but it did not arrive yet.
Have some of you ordered from rumoh.eu before? I sent them a couple of emails about the status of my order but did not receive any response.
Can't wait to install the driver and hear how it sounds!!
I'll let you know!!
Fran
www.22nanofarads.com
Old 30th March 2013, 12:03 PM   #723
xrk971's Avatar
Wow, that's a real bummer. I don't think I have ever built a cabinet without 'driver in hand' before. That's how I know how big to make the cutout for sure. Sorry about your wait.
Old 30th March 2013, 02:24 PM   #724
Thanks X, you're right... Another lesson learnt for my next build!
I downloaded the Fostex specs and cut the front plate's hole according to the manufacturer's info. Anyway I'll wait untill the driver arrives to glue the front plate in case I need to modify the cutout.
Hope the driver gets home soon!!
Old 1st April 2013, 06:17 PM   #725
Ok...have now read the thread in its entirety...almost feel like I know a few of you personally now!
In the early stages of this thread, someone (I believe Cal) talked about utilizing a Radio Shack 40-1354. Has anyone run with this? I know it is much larger than the typical micro-speakers but I have six of them (4 NIB) and have tried them in other kinds of horns that have worked well...
Unfortunately, everything I have is MAC so none of the design programs are available to me any more. Hence, has anyone looked into these? I just got back from the Dollar Tree and now have ten sheets of 20" x 30" that are screaming at me to be cut on...any help would be appreciated!
Old 1st April 2013, 06:30 PM   #726
Speakerholic
Cal Weldon's Avatar
Alright another prisoner. I think it's a better term than addict. At least you have a chance of escaping an addiction. This foam stuff is like a vacuum, it's just keeps sucking them up.
Glad to have you onboard there mcm.
Yes, I thought about the 1354's. They currently reside as the wide range for my main TV. I use some woofers and tweeters with them but the bulk of the octaves are carried by the 1354's so I'm not sure I want to remove them to experiment, they seem quite happy where they are.
I wonder if they might require a cabinet so large that they might be cumbersome. I think you'd want a 32" - 36" square but maybe X can chime in here.
planet10 needs your help:
Let's help Ruth and Dave
Old 1st April 2013, 06:38 PM   #727
I love the 1354's. When RS discontinued them back in 2001, I went to just about every RS in Detroit and bought all they had. I think at one point I had fourty of them or so. I have small ported enclosures in my garage, a simple folded voigt that I gave to a friend, a bi-pole ML-TQWP with the RS/Fostex Horn Tweeter mounted firing up, and even a pair of sealed that I think I will pull out and use for this project if it will work ok.
I could order a pair of 3" speakers to give it a shot, but would love to see what these could do (maybe with addition of a 3/4" textile tweet w/1.0uF?) Getting every last ounce of bass out of these has been a goal of mine....never thought I might be able to rattle windows with them!
Old 1st April 2013, 06:46 PM   #728
Speakerholic
Cal Weldon's Avatar
I didn't notice you were still in moderation so you're now free to roam with the rest of the buffalo.
3"? I only recommend those for your daughter. They are not manly enough for this crowd. Maybe you could do the 1354's but let's wait and see what Grand Poobah has to say. He can't stay away from this thread for long, if fact his ears are probably burning as we type. 32" is reasonable, if you have to go to 36" I think that's a bit much. You could make them deeper but isn't the point of these to be wall mounted?
Old 1st April 2013, 08:22 PM   #729
I could get away with depth....but that width may prove problematic. I was planning on making them completely out of the styro-board as my table saw is still in storage. The pieces I could get were something like 20" x 30", which may prove prohibitive to making them big enough. Maybe I order a pair of those new Mark Audio 3"ers...bet they would make some noise.
Old 1st April 2013, 08:31 PM   #730
Speakerholic
Cal Weldon's Avatar
X must be dead. No way he stays away this long without something bad going down.
Ya you can use a 3" but I have to say, I have tried 5 good sets of 3"ers and it really is night and day with the 4.5's and the larger spiral. It's not even big brother/ little brother, it's father and son difference.
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu Spiral Copy Horn hersh Full Range 24 7th April 2009 07:20 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright 1999-2017 diyAudio
