Ever think of building a Cornu Spiral horn? Now you can! - Page 69 - diyAudio
Old 27th February 2013, 10:14 PM   #681
prezden is offline prezden  Canada
Hi guys
I'm planning on building another pair of Cornus. Gave away the little 8" ones to a friend. The new ones will be 12-13". I'm guessing that a 1.5" driver would be about right. Is that correct? So far I have not had any luck a the thrift stores so may have to buy some new drivers. What would be a good inexpensive speaker?
Love to see all the creative designs on this thread!
Old 28th February 2013, 12:41 AM   #682
xrk971 is offline xrk971  United States
xrk971's Avatar
Prezden,
I saw some of your nice amps in the class D forum. Looks like you like to use the TPA3122 chip and 8 watts power is what you have. I don't know how good this one is but it looks like the ideal driver at 1.8 in and is rated at 8 watts from Visaton.
Visaton Aluminum Cone 4W Full Range Speaker 1.8 Inch | BF 45 | Visaton
The frame mount may be a problem. Otherwise you will have to go up to 2 inches and use something like Visaton FRS5.
Visaton 2 Inch 5W 8 Ohm Miniature Mid Range Speaker | FRS5 2231 | Visaton
Old 28th February 2013, 05:18 AM   #683
Thanks xrk- I'm not sure what amp I will be using with them. I also have a couple modified Sure 2024 amps and a Gain Clone 1875 in the works. Do you think a 2" drive would be ok for a 12" Cornu- not too big? I suppose I could make them a bit larger- maybe 14".
cheers!
Old 28th February 2013, 07:44 AM   #684
xrk971's Avatar
Go for 14 in with a 2 inch driver.
Old 2nd March 2013, 08:56 PM   #685
jsouder is offline jsouder  United States
Default 1" Tangband Speakers
Rebuilt my earlier attempt at using commercial floor tiles for speaker enclosures. This one has the 1" Tangband full range drivers. I used 1/32" fiber gasket material from the auto parts store for the baffles in the 4-horn true spiral layout. Legs are cut from a 3" length of 6" heavy duty plastic water pipe. Still looks nicer than it sounds. May make one more attempt before moving onto another project (which will probably be a 20" circular 6-horn design for 3" NS speakers).
Old 2nd March 2013, 09:14 PM   #686
xrk971's Avatar
Jsouder,
Very cool looking. Floor tiles! Who wouldathunk?
Old 2nd March 2013, 09:42 PM   #687
Jsouder- They look great How do they sound being off the wall?
Old 3rd March 2013, 01:22 PM   #688
Speakerholic
Cal Weldon's Avatar
Ya, you hafta think a 1" driver would benefit the most from wall loading. Is it the bass that's lacking?
What am I saying? It's a 1" driver. That's smaller than some tweeters I know.
planet10 needs your help:
Let's help Ruth and Dave
Old 4th March 2013, 01:40 PM   #689
foamcore...foamcore...
Old 4th March 2013, 02:16 PM   #690
Speakerholic
Cal Weldon's Avatar
Lot's of fun in the 'other' thread. The latest from me is more than I'd hoped.
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu Spiral Copy Horn hersh Full Range 24 7th April 2009 07:20 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright 1999-2017 diyAudio
