Ever think of building a Cornu Spiral horn? Now you can! - Page 55 - diyAudio
Old 3rd February 2013, 08:45 PM   #541
Speakerholic
Cal Weldon's Avatar
Am I seeing that correctly, that the driver is mounted off center so there will be 6 different length horns? If so you certainly have all the bases covered with tuning frequency.
The foam joint tape - is that your spiral template? hehe, what, are you only building two of these?
As far as the glue drying, I would first install a 3/8" wide strip of paper to the cardboard edge with PVA glue, let it dry and then you will have a wider surface to put your glue on for the baffle piece.
planet10 needs your help:
Let's help Ruth and Dave
Old 3rd February 2013, 08:47 PM   #542
Speakerholic
Cal Weldon's Avatar
I don't seem to have any 20" square pieces here so I am thinking about a Suprabaffle instead. Here is the shape I am thinking. It will be made of wood and glued to the foam. Any thoughts?
Old 3rd February 2013, 08:52 PM   #543
Speakerholic
Cal Weldon's Avatar
Originally Posted by xrk971 View Post
Cal,
What size inductor are you using on the 27 inchers?
It was 5.0mH IIRC. I started smaller and just kept upping it till I didn't notice so much overlap with the small driver.
Old 3rd February 2013, 08:53 PM   #544
xrk971 is offline xrk971  United States
xrk971's Avatar
Looks nice Cal. You may want to give the tractrix front horn some consideration. I don't have it mounted yet but holding it in place you can hear a big difference.
Old 3rd February 2013, 09:25 PM   #545
Speakerholic
Cal Weldon's Avatar
No doubt there's a difference, probably a really noticeable one. With me the jury is still out on the FLH's even though I am an owner.
Superbowl time soon. See y'all tomorrow.
Old 4th February 2013, 07:46 PM   #546
Scottmoose's Avatar
And people call me obsessed over the British Grand Prix...
Old 4th February 2013, 08:32 PM   #547
Speakerholic
Cal Weldon's Avatar
Hey Scott, thanks for dropping in. Can't wait till you've got a set of these up and running.
Old 4th February 2013, 08:48 PM   #548
ryani is offline ryani  United States
Hi there, gentelemen. I've been following this thread very closely. AKA lurking for some time.
I have all the material to build a pair of 24" cornu's. I saw xrk971 mention using the TangBand W4-1320SIF and was wondering if it would be a good candidate. If so, what would the height of the spirals? 4.5"? This is my first go and hot glue box building but am excited to try it out. Thanks for all your help and insight. Very impressed with all the knowledge on this forum
Old 4th February 2013, 11:31 PM   #549
xrk971's Avatar
Ryani,
4.5 to 5 works, stick w 4.5 to be thinner.
80% compression factor for 57 cm sq Sd.
Old 4th February 2013, 11:58 PM   #550
Thanks a million xrk971! I appreciate it. I' m going to get all the internals cut tomorrow night and employ the better half's hands this weekend to get them glued up. Weather is supposed to be crappy so it will be a great inside job.
I will get some pictures up when I get them stuck together.
Thanks again
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu Spiral Copy Horn hersh Full Range 24 7th April 2009 07:20 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright 1999-2017 diyAudio
