Ever think of building a Cornu Spiral horn? Now you can! - Page 54 - diyAudio
Old 2nd February 2013, 04:48 PM   #531
rock12 is offline rock12  United States
well I have been listening for a while and really am impressed. I think my stuffing might not be right Bass is a little loud(boomy) Stuffing is in the center chamber and the first 8" of the spirals. Friend is working on artwork for the face should be nice ahen done
Old 2nd February 2013, 04:58 PM   #532
xrk971 is offline xrk971  United States
xrk971's Avatar
Rock,
Awesome great news! Looks like the 315e's are working out well then. Crazy that it is too boomy for a little driver like that. Pack more stuffing into the chamber that might help. Any pics?
Congrats.
Old 2nd February 2013, 05:12 PM   #533
Speakerholic
Cal Weldon's Avatar
Pictures!
planet10 needs your help:
Let's help Ruth and Dave
Old 2nd February 2013, 11:18 PM   #534
Speakerholic
Cal Weldon's Avatar
I got a little carried away last night. While the cat was away, I decided to push my luck a little. I had been talking music with the captain (Morgan) so I was feeling no pain and wanted to see what happens when you let the volume control slip a bit. I am running the Tascam 30 watt mini PA amp. The drivers are the CSS VWR126's with a big ol' choke and the JVC white cones with a 50 fd cap.
They did not disappoint. They held their own like you would expect a party speaker to do. Lots 'o' bass and the highs were nicely controlled like you hope to get from a small driver. Not sure you could call this a FAST system but why not? I had those little drivers just a pumpin' and this morning my ears were still ringing.
Yes, I was surprised, yes I was stupid to push the expensive CSS drivers like that but what the hey, they handle a lot more than I was putting into them and I was sitting there with a big audio woody once again.
Thanks X, there's a lot of fun to be had here.
Old 2nd February 2013, 11:28 PM   #535
xrk971's Avatar
Cal,
That sounds like fun Wish you had a video or sound clip. A 4.5 in subwoofer FAST.
Old 3rd February 2013, 04:36 PM   #536
Speakerholic
Cal Weldon's Avatar
The 20" are going through a change. Will post pics later.
Old 3rd February 2013, 05:04 PM   #537
Six horn Cornu on the way.
I started the inner spiral with 1/16 inch white cardboard to keep the throats as large as possible. This will be a bit tricky when gluing on the cover plywood sheet. Wonder if I can get the glue on all the spiral arms before it starts setting up.
I used Phenoseal adhesive caulk.Click the image to open in full size.
Old 3rd February 2013, 06:06 PM   #538
xrk971's Avatar
Cal,
I can see lots of patchwork on the 20's - your try out new drivers cabinets. What size inductor are you using on the 27 inchers?
Old 3rd February 2013, 06:15 PM   #539
Speakerholic
Cal Weldon's Avatar
Nice job so far glowglass.
Originally Posted by xrk971 View Post
Cal,
The Fostex FF125 are back in the big boxes, the CSS 126 are back on the shelf and the 20" have had the patchwork partially removed, the driver hole filled then a full sized piece of foam over the whole thing so it is 3 layers thick now. The other side will have a full sized piece of wood and will become the new baffle for the JVC drivers. I want to hear what become of the other experiments to determine exactly what to do with the CSS 126's and the small LG drivers that I like so much.
Catch all that?
Old 3rd February 2013, 06:52 PM   #540
xrk971's Avatar
Glowglass,
What you are doing is truly out of the box and it looks fantastic! To think there are going to be two layers to this horn. Wow this thing will be awesome. Love what you did with the cardboard inside. You may want to reinforce middle chamber with some threaded rods and sleeves to give more strength to thin cardboard area. I can't wait to see this completed and your first sound. Great handywork and attention to detail. Very nice!
On second thought, you don't need fancy threaded rod. Just some wooden dowels glued in place inside the driver chamber near the edges should do the trick.
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu Spiral Copy Horn hersh Full Range 24 7th April 2009 07:20 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright 1999-2017 diyAudio
