Ever think of building a Cornu Spiral horn? Now you can! - Page 50 - diyAudio
Old 28th January 2013, 12:39 AM   #491
xrk971 is offline xrk971  United States
xrk971's Avatar
How do they sound, Cal?
Old 28th January 2013, 01:03 AM   #492
xrk971's Avatar
I got a reply to my PM to Hersh (Sebastien Pitkanen). He said that when he did the cornu, he talked to Daniel and the double layer plan with the semi-curved design was supposed to be the final optimized design. Apparently there is supposed to be something to that design and having 8 flow channels or horns that makes a difference. It would be interesting for somebody to make an exact copy with two layer horn in foam core in the full 70 cm size and use recommended driver (Monacor or FE108Esigma) and do a measurement. Anyone have a FE108ESigma handy?
Old 28th January 2013, 02:55 AM   #493
Speakerholic
Cal Weldon's Avatar
Dave does but I'm not sure if he's doing the cornu anytime soon.
planet10 needs your help:
Let's help Ruth and Dave
Old 28th January 2013, 02:57 AM   #494
Speakerholic
Cal Weldon's Avatar
Four of them sound good. The two that I wouldn't recommend for this application are the slightly smaller chinese driver with the recessed flange (third from the left) and the Jordan.
They all need to be pushed right against the wall to achieve decent bass, no wiggle room on that.
The $2 Aura is no slouch so it definitely wins the economy division.
The more expensive Aura and the JVC drivers are similar with the LG's slightly in the lead. But as mentioned the jury is still out, too soon to say for sure.
Old 28th January 2013, 02:58 AM   #495
frugal-phile(tm)
planet10's Avatar
I have FE108 but not handy.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th January 2013, 02:59 AM   #496
xrk971's Avatar
So the $2 Aurasound is good? That's a good deal, I might have to get some.
Old 28th January 2013, 03:06 AM   #497
Speakerholic
Cal Weldon's Avatar
The $2 jobs are the 4th best of the 4 that sound good.
Old 28th January 2013, 03:14 AM   #498
xrk971's Avatar
dave
Do you think a Tang Band W4-1320SIF bamboo cone driver is close enough? Qts is 0.34, Bl is 5.3, Vas is close, Sd a little bigger, efficiency down to 88 dB, biggest difference is xmax at 3 mm vs 0.28 mm on FE108ESigma.
Old 28th January 2013, 01:07 PM   #499
kambule is offline kambule  Hong Kong
Mr. xrk, I got some spare HiVi B3s. Are they good for your 20 inch design ? I shall keep the
throat 3 x 1.2 inch. Since they are heavier, I guess double foam core board for the panels is
required.
Another question, what is the major difference between the foam board used in the cartoon boxes and
the foam core board ?? Can I strengthen the foam board by sticking the self-sticking wall paper ??
Old 28th January 2013, 01:27 PM   #500
hajj is offline hajj  Lebanon
hajj's Avatar
Just a quick note, with such small chambers relative to the drivers' magnet size, one should consider volume taken up by the magnet in the chamber when/If optimizing the design.
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu Spiral Copy Horn hersh Full Range 24 7th April 2009 07:20 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright 1999-2017 diyAudio
