#411 | |
frugal-phile(tm)
at the air cavity cutoff frequency, the distance the back wave has to travel down the horn and out to your ear should be (2n+1)/2 (n = o or any positive integer)* wavelengths of cutoff frequency further than the direct travel from the front of the cone to your ear. *(odd number of half wavelengths) In other words an approriate upper cutoff has a limited number of discreet values. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#412 |
I think George mentioned this in one of the earlier posts. This is to prevent cancellation of the back and front wave right? When you say air chamber cutoff do you mean the higher freq cutoff based on chamber volume and throat area?
#413 |
frugal-phile(tm)
Yes. Yes.
dave
#414 |
frugal-phile(tm)
Yes. Yes.
dave
#415 | |
Right now I am using an ODAC, JLM 06 pre and a 2024 amp. I'm hoping to make a gainclone for them in the future. cheers |
#416 |
Prezden,
One other question. Are your electronics (pre and power amp) housed in thos little pine boxes on the lower right? At first I thought they were just keepsake boxes but noticed knobs and toggle switches on the front, Very earthy in keeping with the hand made paper baffles! Nice. |
#417 | |
#418 |
Speakerholic
Since I can't really help myself I stopped in at not one but two different Sally Ann's.
What I found at the 1st resembles the LG in appearance but they are a little light in the top end. Made by JVC in China they were solo in small ported boxes. They have a stronger bass but not good as a tweeter. Kinda half way between the Fostex 125's and the LG's. On axis they are fine but fade quickly off axis. |
#419 |
Speakerholic
Since I pulled the LG's here they are. Superb vocals and up.
#420 |
Speakerholic
This is the other 'discovery' that I would like to try in a little Cornu. It's the first driver I have known that has to be back mounted. The 3rd pic shows why.
| Line array cornu spiral? | jaylgordon | Full Range | 5 | 19th May 2009 05:20 PM |
| Cornu Spiral Copy Horn | hersh | Full Range | 24 | 7th April 2009 07:20 PM |
| Cornu spiral horns | Cal Weldon | Multi-Way | 3 | 14th July 2004 02:51 PM |
