#321 |
Speakerholic
Nice job there Xerxes!
#322 |
Speakerholic
Well I must say it's another successful build. I remeasured the cone. It's a mere 24 cm^2 so smaller than tweeters of yesteryear.
#323 |
Cal,
Looks fantastic! Congrats Your edges and cuts look very clean. How was it building in all foam this time? And you are killing me with anticipation.... how do the Jordan's sound in the spiral?
#324 |
Speakerholic
Thanks X,
They sound better than in any other box I've tried. There's actually a hint of bass.
#325 |
Is it my imagination but those Jordan's resemble Mark Audio's in frame, cone, and terminal locations. What is the Fs of this driver?
#326 |
Speakerholic
Other way round. Mark used to work for Ted Jordan before starting Mark Audio. The drivers are old enough that I can't find much on them but this is about the 3rd generation of the 50mm cone drivers. There is only a surround, no spider so you have to be careful with excursion.
I would guess the Fs to be in the neighbourhood of 100Hz, maybe a bit less as they have a recommended XO of 120Hz when used with a woofer. Sensitivity is about 80 or 82 dB. EDIT: I may not be right about the above as the driver cone is a little bigger than 50mm [hence the 6T designation?], more like 54mm and I have learned the 50mm cones had a very high Fs and a Qts well above 1.0 so I'm not sure what these are. |
#327 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#328 |
Speakerholic
Thanks Dave, always a wealth of knowledge.
#329 |
Speakerholic
I am thinking.
I know that scares the people who know me so let me clear the air. This is about speakers. I have to fulfill my duty as 'yes man' for my honey but when I am done, I'm going to hang a big ol' choke on the larger Cornus and a giant cap on the new ones and run them together as they seem to each have a niche to fill. |
#330 |
Awesome, a giant cornu two-way wall speaker. Hey you are in the wrong forum if you do this
| Line array cornu spiral? | jaylgordon | Full Range | 5 | 19th May 2009 05:20 PM |
| Cornu Spiral Copy Horn | hersh | Full Range | 24 | 7th April 2009 07:20 PM |
| Cornu spiral horns | Cal Weldon | Multi-Way | 3 | 14th July 2004 02:51 PM |
