Ever think of building a Cornu Spiral horn? Now you can! - Page 23 - diyAudio
Old 30th December 2012, 09:09 PM   #221
frugal-phile(tm)
planet10's Avatar
Originally Posted by Cal Weldon View Post
MA A6P
A6.2M might be a better choice for this enclosure.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th December 2012, 09:12 PM   #222
xrk971 is offline xrk971  United States
xrk971's Avatar
Chaz,
Those look great! It's going to work just fine.
Old 30th December 2012, 09:18 PM   #223
xrk971's Avatar
Wow, that is a great deal on those 16 ohm NS3's at $2.50!
The Madisound Speaker Store
Old 30th December 2012, 09:26 PM   #224
frugal-phile(tm)
planet10's Avatar
I'm getting 100 for an EnABL trainee to practise on.
dave
Old 30th December 2012, 09:43 PM   #225
Fenris is offline Fenris  United States
I've been listening to my Cornu horn for about a week now. I built mine using the Elmers foam with the heavy paper backing for the front and back sheets. The inner spirals were made using the dollar store foam board. Size is 20" square with a 2.5" internal depth.
To draw the spirals I used a projector and projected the spiral onto the foamboard while it was taped to the wall and adjusted until it fit, then traced in pencil. Very fast and easy. I glued the inner spirals to the back using standard hot melt glue. My plan has always been to cover these with a cloth "sock" to make them decorative wall pieces. I knew that I had to recess the driver a bit and needed something for it to securely mount to, so I decided to use a piece of 1/4" craft plywood and some dowels to make a mount and support behind the driver. I made small rebates to align the dowels in the ply. I also chamfered the ply where it met the horn inlet. I used short pieces of bamboo skewers at the leading edge of the foam horn inlets to round over the edge. To score the foam, I used a roller paper cutter - it only cuts 1/16" deep and makes fast work of the scoring.
The back plywood piece was glued on with wood glue, as were all the wood pieces. The hole in the plywood was cut with a 76mm hole saw, as was the hole in the foam. Then I traced out the driver frame on the front and removed the top layer of paper and the foam to provide a small recess for the driver. The top was glued on with adhesive caulk - it's cheap, easy to apply, has about a half hour of working time, and fills gaps easily.
The sound? Not as good as the speakers below them, but darn good for 1/10th the price. There's definitely some peakiness that is noticeable, but the bass is impressive for a 3" speaker. Stuffing isn't optimal - four layers of felt behind the driver and as much polyfill as I could get in the chamber. I probably should have stuffed some of the line, but I was afraid of overstuffing and not being able to remove it. I do notice a lot of highs coming through the back, probably due to the lightweight materials.
I had a few leftover pieces of foamboard so I made a small craft project for my kids. This foam is good stuff.
Listen to the music through the stereo, not the stereo through the music.
Old 30th December 2012, 09:44 PM   #226
Speakerholic
Cal Weldon's Avatar
Nice work Chaz.
I must say I am worried about you doing the stuffing and closing up the box unless you do as xrk suggests and make sure you can change it if you have to. If you over stuff it, you lose the value of this cabinet. I would do it at the end and make a cup shape for the chamber and use a fork if you want to add some to the throats. Stuffing makes more difference than almost any cabinet, so you have to get it right or you may miss the magic.
planet10 needs your help:
Let's help Ruth and Dave
Old 30th December 2012, 09:47 PM   #227
Speakerholic
Cal Weldon's Avatar
Great work too Fenris. Can't stress enough the importance of your statement.
Good Daddy.
Old 30th December 2012, 10:08 PM   #228
xrk971's Avatar
Very nice work Fenris. I like what you did with the wood driver mount. It looks like you used the $10 buyout TB w3-881si and it sounds good. Awesome to hear. Lots of good tricks you mentioned like the roller cutter for scoring. I have some of that nice Elmers foam board too, looks like it works out well as a baffle. Thanks for sharing.
Old 30th December 2012, 10:26 PM   #229
prezden is offline prezden  Canada
Here is another project in the works. I'm a little hesitant to post my effort so far. It looks pretty shabby compared to the ones by chaz and fenris
Old 30th December 2012, 11:00 PM   #230
Speakerholic
Cal Weldon's Avatar
Hey, us Canadians... we stick together. Yours look just fine.
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu Spiral Copy Horn hersh Full Range 24 7th April 2009 07:20 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright 1999-2017 diyAudio
