Ever think of building a Cornu Spiral horn? Now you can! - Page 166 - diyAudio
Old 6th May 2014, 09:24 AM   #1651
Coen is offline Coen  Netherlands
And here is the happy couple and they do sound really good. Can't wait to get them up on the wall. The construction glue allso works really well, i can recommend it over the polyurethane glue.
Old 6th May 2014, 11:32 AM   #1652
xrk971 is offline xrk971  United States
xrk971's Avatar
Nice work Coen! Remind us what driver that is and what size you ended up making?
Old 6th May 2014, 12:49 PM   #1653
Speakerholic
Cal Weldon's Avatar
Sure looks like a Fostex to me.
+1 on what X said.
planet10 needs your help:
Let's help Ruth and Dave
Old 6th May 2014, 12:53 PM   #1654
Thanks It's a fostex FE103En in a 60cm / 24inch wide 8cm / 3.14inch deep cornu. The drivers had matching screws but they where to large for the 5mm thick front, so now i'm stuck with these ugly ones untill i can find something better
Old 9th May 2014, 06:01 PM   #1655
Ok, i decided to do something about the screws today since the rvs ones are terrible for the WAF.
As you can see the screws that came with the drivers have a non threaded part which is about the size of the mdf i used..
After visiting a few stores i found out no-one is selling nice and shiny black round screws, so i got the next best thing.. nice and shiny gold looking ones...
which will probably still look ugly when used with the drives, but on the up side: the shape looks about right.
So then i got these, the cheapest spray paint i could find
Now this is with a few base coats
And then with the black finish.
Waiting for the paint to dry... They almost look like the original ones now, i just hope the paint doesn't come off when i screw them in
Old 9th May 2014, 06:25 PM   #1656
Speakerholic
Cal Weldon's Avatar
I think I might have just glued small pieces of MDF to the backside of the baffle so I could use the original screws.
Old 9th May 2014, 06:30 PM   #1657
because the driver is a little larger then the original mounting hole and with the square shape it, the screw holes are almost on top of the foam. Making it very hard to glue something in ..and this is more fun.
Old 10th May 2014, 03:43 PM   #1658
Screwing them in did damage the paint a little, but that is only noticable from up close. Problem solved
Old 10th May 2014, 10:11 PM   #1659
xrk971's Avatar
Looks great Coen! Tip: use a black Sharpie permanent marker to touch up the paint.
Old 10th May 2014, 11:56 PM   #1660
tfcx is offline tfcx  United States
Also(for next time), you might try putting a piece of masking tape on the screwdriver tip prior to driving the screws.
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu Spiral Copy Horn hersh Full Range 24 7th April 2009 07:20 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright 1999-2017 diyAudio
