Ever think of building a Cornu Spiral horn? Now you can!
Old 17th February 2013, 08:01 PM   #631
guangui is offline guangui  Puerto Rico
Originally Posted by Switters View Post
Hi solhaga,
I had the same problem, I used vinyl glue to seal the back panel and this leaved some leakage. I tried to seal them pouring some glue from the horn mouth and then rotating the cabinet to let it flow along the corners formed by the plywood and the foamcore board.
In my experience vinyl glue is too liquid, it's easily absorbed by wood and "shrink" too much when drying. Next build I'll try a more dense glue.
Wouldn't Contact Cement be a good alternative?
Old 17th February 2013, 08:04 PM   #632
solhaga is offline solhaga  Sweden
I use silicone sealant:
Old 17th February 2013, 09:13 PM   #633
Switters is offline Switters  Italy
I never tried contact cement but if it is fast setting or if there are solvent reacting with polystyrene I wouldn't use it, otherwise it should be ok.
From the photo it seems that horn throats are closed... or it's a trick of my declining sight?
Old 17th February 2013, 09:32 PM   #634
No, they are not closed. The foam I´m using is not rigid enough so I have to put spacers at the top. Like bridges.
Old 17th February 2013, 09:45 PM   #635
Mmm... this could be an useful trick, thank you
Old 17th February 2013, 11:43 PM   #636
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
solhaga, you, without a doubt, win the ugly award. They might be the best sounding of the bunch but OMG man!
planet10 needs your help:
Let's help Ruth and Dave
Old 18th February 2013, 12:04 AM   #637
LOL, but once he puts the front baffle in place you will not be able to see the mess inside.
Old 18th February 2013, 01:05 AM   #638
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Solhaga,
What are the channels made of? Black foam core or is that like vinyl? There are no points for internal beauty as long s it sounds good if channels are foam core and cut cleanly, they seal nicely with cheap white glue. They are also stiff in compression and would not require bracing at throat.
Old 18th February 2013, 01:43 AM   #639
turk 182 is offline turk 182  Canada
well holy cow i was walking through the mall and i saw an "OPENING SOON" sign for a Dollar Tree store. soon i too will have foamcore at LAST!
hey can we change the name and call foamcore cornu's to cornFu's (the capital F is in praise of foamcore)
Old 18th February 2013, 03:35 AM   #640
Originally Posted by xrk971 View Post
Solhaga,
It is 5mm XPS foam that is normally used as floor underlay.
Ever think of building a Cornu Spiral horn? Now you can!Hide this!Advertise here!
Cornu Spiral Copy Horn hersh Full Range 25 30th January 2018 01:32 AM
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
