Ever think of building a Cornu Spiral horn? Now you can!
Old 16th January 2013, 04:27 PM   #431
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Originally Posted by xrk971 View Post
Where are you getting them for 4 for $9?
The centre channel plus the left and rights from an incomplete set of Panasonic plastic speakers. $2.99 per piece, no tax. All I do is pick them up and if plastic speakers are heavy, I take a chance
The JVC's on the other hand came in a very nice, curved sided box with a flared port and a neat grill mounting system. Those were $20 for the pair. High priced by Sally Ann standars but they looked and felt good. So far they are real goodies. As mentioned the high end is good if on axis.
planet10 needs your help:
Let's help Ruth and Dave
Old 17th January 2013, 03:04 AM   #432
xrk971 is offline xrk971  United States
xrk971's Avatar
Ahh... so the trick for shopping used cheap speakers is the weight. A sure sign of a big magnet. I will keep this in mind the next time I am at a thrift store or a garage sale.
Don't know if you have Ross stores in Canada, but they sell discount clothes, housewares, bedding, etc. They often have deals on computer speakers and other electronics in a grab bin near the front. I still kick myself for not grabbing the nice concave style 2 in aluminum drivers with rubber surrounds in nice housings when I was there last time. Amp and all for $10. Would have made a nice set of desktop Cornu's.
Old 17th January 2013, 03:23 AM   #433
Speakerholic
Cal Weldon's Avatar
Maybe not in Canada but an hour south of the border, once a year I take my honey to Bellis Fair Mall in Bellingham Wa. I drop her off, go to the 'something or other country buffet' and meet up with her later after I'm too full to be useful.
Are you telling me I should shop with her at Ross? You're really cramping something here X.
Old 17th January 2013, 10:26 AM   #434
xrk971's Avatar
Eating fest vs. shopping fest... The shopping is a lot more palatable knowing there may be some speaker deals to be had. Don't tell your honey that you are actually lurking for speakers and she will think you are just sweet for tagging along and accompanying her on her yearly pilgrimage to Ross. Don't worry, we won't tell.
Old 19th January 2013, 01:43 PM   #435
zayne742 is offline zayne742  United States
Default Finally Ready to Build
Finally moved, getting settled, cannot fight the urge anymore!
Been following every word on the thread, so my question is, Is there any experimentation that needs to take place with the chamber etc?
The driver I am starting with is a 2" Tymphany, specs:
Power handling: 10 watts RMS/20 watts max VCdia: 13/16" Le: 0.12 mH Impedance: 8 ohms Re: 7.1 ohms Frequency response: 148-20,000 Hz Fs: 148 Hz SPL: 83.7 dB 1W/1m Vas: 0.008 cu. ft. Qms: 3.4 Qes: 0.54 Qts: 0.46 Xmax: 1.45 mm Dimensions: Overall diameter: 2-5/8", Cutout diameter: 2", Depth: 1-3/8".
Was thinking about a 14"-15" unit. Any ideas or thoughts that need testing? Ready to build and report back!
Fliping Switches, Pushing Buttons, and Turning Knobs.
Old 19th January 2013, 02:13 PM   #436
xrk971's Avatar
Zayne,
Good to hear you are rearing to jump in to this! What is the Sd of the driver? A typical 2 in class driver will have Sd of about 15 cm^2. There is some experimentation regarding driver chamber volume vs throat area and how this affects the upper cutoff freq. I suggest you first make a standard plan cornu, then you can play with adding volume filler to the chamber. For the driver you are selecting, a 15 in may be a good idea x 2 in to 2.5 in deep depending on how big the Sd is. Either will work but it changes how much midrange comes out if horns. I have made a 14 x 2 in cornu for a 2 in Visaton FRS5 look alike driver and it works very well. I think the Tymphany has more Sd and certainly more xmax and lower Fs so a larger size may benefit, hence the 15 in.
Good luck!
Old 19th January 2013, 05:37 PM   #437
prezden is offline prezden  Canada
Hi guys- I am thinking of making another pair of Cornus using a couple pieces of art that I have. They are 12" square. Given that parameter what size driver would be ideal. I'll be going thrift store shopping to try and find something suitable. Would a horn depth of 2" be right for this size?
By the way- I love the 2 sets I have already built- can't believe the sound
cheers
Old 19th January 2013, 06:08 PM   #438
xrk971's Avatar
Prezden,
Can you mount the art on a 14 in foam core board and use suitable framing or mattes to cover the 2 in border? The 14 in size is as small as I would want to go with a 2 in driver. For 1 in driver didn't you make thiose tiny closet speakers? A 1 in driver could be used in a 12 inch cornu. I would probably make it 2 in deep to get about 5 cm sq cm of throat area. The foam will take up significant channel throat width and I think throat gap will be about 0.2 in wide. Assuming this, the depth of channel needs to be about 2 in still.
Good luck on your search for used drivers.
Old 19th January 2013, 09:55 PM   #439
Illusus is offline Illusus  Canada
Illusus's Avatar
I built a pair of these a couple weeks ago for my son's room. 20"^2 x 2"D - 2" drivers from a logitec speaker. I didn't put too much care into the build but they sound pretty good and look okay. Unstuffed they sounded terrible (!) but are great with a fistfull of wadding. Thanks for the idea guys!
Fighting the program since 1976.
Old 19th January 2013, 10:17 PM   #440
xrk971's Avatar
Illusus,
The artwork looks great, did your son paint them? 20 in is probably too big for the 2 in drivers as the fs of the driver is way above the low freq of the horn, but hey, it sounds good!
Congrats!
Thanks for sharing.
Which Logitech model?
Ever think of building a Cornu Spiral horn? Now you can!Hide this!Advertise here!
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 07:43 PM
Cornu Spiral Copy Horn hersh Full Range 24 7th April 2009 07:20 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 02:51 PM
Copyright ©1999-2017 diyAudio
