Ever think of building a Cornu Spiral horn? Now you can!
Old 14th January 2013, 08:28 PM   #401
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by xrk971 View Post
... this drives the cutoff frequency up into the 300 Hz range.
... and adding some stuffing actually stretched it upwards of 400 to 500 Hz which may be too much upper bass
300 Hz is more like a maximum, not a target.
MidBass is 40-80 Hz. With the smaller drivers you are struggling even to get into the midbass.
Upper Bass is 80-160 Hz.
Lower Midrange 160-320 Hz.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th January 2013, 08:29 PM   #402
hajj is offline hajj  Lebanon
hajj's Avatar
xrk971,
It is considered a good rule of thumb to never make a horn's bandwidth more than two octaves (e.g. 50-200hz), this is made to keep phasing issue to a minimum IIRC.
Furthermore, getting a horn up to the 300hz range will yield more harm than good, at this frequency, most drivers (bigger than 2inches) response will be practically at the driver's nominal SPL, and the phase difference and distance between driver and horn mouth will cause a lot of dip.
A horn should be used to effectively boost the driver's response as it falls, which in the case of most drivers mentioned so far in this thread, is around the 100hz mark.
I hope I am being clear enough, long day at work, brain nearing clinical death.
Nick
Old 14th January 2013, 08:30 PM   #403
hajj's Avatar
Dave beat me to it
He's better at it than I am anyway
Old 14th January 2013, 08:40 PM   #404
xrk971 is online now xrk971  United States
xrk971's Avatar
Planet10 and Hajj,
Thanks for the feedback. So perhaps, the addition of too much volume filler is not needed. I will work on determining the horn length and mouth needed to get down below 100 Hz and should I limit the max upper horn frequency to 160 Hz? Maybe it's my ears and the type of music I like to hear but some of the peaks at the cornu puts out in the 200 to 300 Hz range sound pleasing to my ears. By no means is this a speaker that is neutral -t definitely has flavor or as some call it, colour to the music.
Old 14th January 2013, 08:51 PM   #405
prezden is offline prezden  Canada
Well I finally completed the 16" Cornu build and must say they sound great. And that is with a pair of brand new TB W3-881SJF's. I can only guess how they will sound when broken in.
Yesterday evening a friend came over and we spent a couple hrs. listening to a variety of jazz and classical. I haven't been that blissed out listening to music for a long time.
Thanks to all for your help and encouragement.
Old 14th January 2013, 08:54 PM   #406
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Funny, that is in the range of what I like to EQ out.
planet10 needs your help:
Let's help Ruth and Dave
Old 14th January 2013, 08:56 PM   #407
Speakerholic
Cal Weldon's Avatar
Those look great prezden. Is that a wallpaper on them? I might have missed you telling us.
Also really glad you like them. Your reaction sounds similar to many of us.
Big difference from the closet door ones?
Old 14th January 2013, 09:00 PM   #408
xrk971's Avatar
Prezden,
Very nice job! They look fantastic mounted on the wall - I am happy to hear that they sound great and you are enjoying listening to the music. The cornu is what made me want to listen to music again - it has a special sound. Do you mean the W3-881sif clearance drivers for $10 ea? There is a good deal in great sounding and nice looking speakers for you. What depth did you make the 16 incher and which plan are you using?
Congrats!
Old 14th January 2013, 09:10 PM   #409
Thanks guys
The front cover is a heavily textured hand made paper but wall paper would work just as well. I also made the front 1/2" all round bigger than the actual box so you don't see the edges and It gives them a sense of floating off the wall.
I got the drivers from Solen for about $16. each.
Old 15th January 2013, 02:50 AM   #410
xrk971's Avatar
Originally Posted by prezden View Post
Thanks guys
Your handmade textured paper looks great on the Cornu's. Where do you buy it or do you make the paper yourself? What amp are you using to drive the 16 inchers?
Ever think of building a Cornu Spiral horn? Now you can!Hide this!Advertise here!
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 08:43 PM
Cornu Spiral Copy Horn hersh Full Range 24 7th April 2009 08:20 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 03:51 PM
Copyright ©1999-2017 diyAudio
