Ever think of building a Cornu Spiral horn? Now you can!
Old 8th January 2013, 12:38 AM   #341
xrk971 is offline xrk971  United States
xrk971's Avatar
Originally Posted by Jim Shearer View Post
Cal & XRK,
I'm getting ready to start a pair of Cornucopya's with the Altec Lansing 405A drivers I have. Near as I can tell, the 405A is close to the same size as the FF125wk, although when I measure the cone, it looks to me like 8.5 cm dia. pistonic size, or an S(d) = 57 cm**2, compared to the FF125wk spec of S(d)= 66.5 cm**2.
When I plotted the spiral (which Cal appears to have used at the start of this thread) for a 27" horn, I find a CC measuring 4.5" x 5" with throats about 17mm wide. If I use a channel depth of 5", this comes out to 43 cm**2 total for the two throats.
How do I get the total throat area up closer to S(d) which IIRC is what you recommend? Shrink the CC a bit?
Thanks, Jim
Jim,
There are several ways to expand the throat area: custom draw the channels to have a wider throat if you want to keep external dimensions the same; increase depth of channel, or grow whole cabinet. Note that some compression is ok, if ratio of throat area to Sd is greater than 75%, it's probably ok. For low Qts, high Bl drivers with low xmax, you might want more compression to load driver and reduce excursion. It should be modeled - a simple model in HornResp with a conical horn for first section to exponential horn near mouth wirh
appropriate dimensions for driver chamber will tell you a lot about excursion of cone.
If you are using the plan from planet10's pdf diagram, I think the the throat width is 0.9 in for the 27.6 in cornu. That is 2.3 cm wide not 17 mm wide. This gives a throat area of about 57 cm^2 for a 5 in deep channel. This about a perfect match for your driver if you wanted no compression. You could probably go as thin as 4 in and be ok.
What are the T/S params for your Altec driver?
Good luck!
Xrk971
Old 8th January 2013, 12:57 AM   #342
prezden is offline prezden  Canada
Hey Cal- I was just looking at your speaker projects. What on earth do you do with all that marvelous stuff?
Old 8th January 2013, 01:27 AM   #343
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Unless you and the others gives us a first name, that's a secret.
I have further listened to to the LG's and I don't know what to say. My wife is in the bath and she asks [honest to Jimmy], are those the new ones?
3" speakers doing that?
planet10 needs your help:
Let's help Ruth and Dave
Old 8th January 2013, 01:40 AM   #344
xrk971's Avatar
What are the LG's?
Old 8th January 2013, 03:07 AM   #345
Speakerholic
Cal Weldon's Avatar
Post 340 tells you what I know. I wish I had more of them, seriously.
What I can say is they sound really nice, they are better than expected.
Jimmy appreciates that.
Old 8th January 2013, 03:36 AM   #346
xrk971's Avatar
Cal,
I missed that post somehow. Glad they sound good, do you have any photos? Are these one of those concave aluminum dome drivers? Who is Jimmy? Buffett?
Old 8th January 2013, 04:44 AM   #347
Closet door stereo
Old 8th January 2013, 07:48 AM   #348
xrk971's Avatar
Prezden'
Very nice setup there!
Is that the Sure TPA3110 amp you are using? How do you like it?
Old 8th January 2013, 09:33 AM   #349
Don Hills is offline Don Hills  New Zealand
Originally Posted by xrk971 View Post
I was wondering what a Cornu horn would look like if we were to actually use the true Cornu function which is also known as a clothoid. ...
Nice work. Did you notice something something pretty significant? The resulting horns closely follow an exponential length/area law. You can model single-spiral (divided 4 ways) Cornu horns in Hornresp using a single exponential section, and the multi-length horns like the one in your post in AkAbak. I'll modify (simplify) my AkAbak model accordingly.
Old 8th January 2013, 10:14 AM   #350
nathanjh13 is offline nathanjh13  United Kingdom
Hello. Has anybody tried this with a different enclosure shape? Aesthetically I was thinking about a circular overall shape rather than square. Good idea? Many thanks for any advice.
Ever think of building a Cornu Spiral horn? Now you can!Hide this!Advertise here!
Line array cornu spiral? jaylgordon Full Range 7 15th December 2013 08:43 PM
Cornu Spiral Copy Horn hersh Full Range 24 7th April 2009 08:20 PM
Cornu spiral horns Cal Weldon Multi-Way 3 14th July 2004 03:51 PM
Copyright ©1999-2017 diyAudio
