FAST-ish enclosure help.
Old 22nd December 2012, 05:02 PM   #11
GM is offline GM  United States
GM's Avatar
Originally Posted by gafhenderson View Post
I do understand that, I'm not entirely sure how this fits in with my question tho, sorry.
It doesn't seem so since the fundamental [low] frequency is the 'foundation' of all sound.
Historically then, the bass BW reproducer is designed first, then the mids, HF. If a true sub system is used, then this is the foundation.
That said, I keep forgetting that around here the wide BW driver is typically chosen first, then any bass, HF augmentation is tacked on.
Fortunately, the woofer, [super] tweeter selection is so large nowadays that given time one should be able to find a close enough fit or at least one that can be blended with a custom XO that now can be easily designed using either software or adjustable digital XO.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd December 2012, 05:13 PM   #12
GM's Avatar
i've seen Planet10's FAST system's with side mounted woofers, can this work with any woofer and design?
Ideally only if the woofer[s] acoustical center[s] are < 1/4 WL away from the XO's -12 dB point, so the higher the slope order, the greater the mounting gap can be.
Since our hearing acuity dramatically degrades down low, many folks can tolerate up to 1 WL away, so it depends on the person's hearing and the room's acoustical conditions that will set the max acceptable offset.
GM
Old 22nd December 2012, 05:16 PM   #13
GM's Avatar
if this is the sim for the above design, would the sealed plot work well enough to cross to the bass units?
Yes, though you'll probably need an adjustable digital XO to dial it in if you don't have measured in room responses to plug into a computer program.
GM
FAST-ish enclosure help.Hide this!Advertise here!
A fast way to build FAST solhaga Full Range 36 15th December 2012 10:32 AM
FAST woofer rec for 6 liter enclosure toobhed Full Range 3 8th March 2012 01:48 AM
Adding a woofer into a Pensil enclosure? FAST project with active crossovers southernoise Planet 10 hifi 8 11th October 2011 04:27 AM
Driver/enclosure to complement Alpair 10.2 FR Pensil in a FAST system? southernoise Planet 10 hifi 24 7th February 2011 01:04 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
Copyright ©1999-2017 diyAudio
