#11 |
#12 |
No, that dip is a phase issue due to a sort of mechanical crossover I'm guessing.
It must be some sort of transition from piston behavior to oscillatory behavior.
I LIKE YOU
#13 |
Id like to see the distortion measurements Ben, if ya could? Pretty please
I LIKE YOU
#14 | |
Not sure I like the 20% +/- Fs variation, since that could put a pair of drivers at anything up to 34.4Hz apart in resonant frequency, although given the price, can't really complain.
#15 | |
But still, it's something to ponder for a cheap, effective surround speaker. I'm thinking a composite decking post with one of these on top, and maybe four Aura NS3's (unless there's a longer-throw 3"-4" driver of which I'm unaware) in series-parallel on the floor.
Serious Audio Blog |
#16 |
#17 |
I listened to a few TV shows on the HiWave center channel today and found that, even with the center set to +8 dB in the receiver, the dialog was low compared to the music emitting from my reference speakers. I upped it to the max (+10 dB) and will try again.
The intelligibility was good, just not loud enough relative to the mains (which are not particularly efficient mind you). Sounded recessed, for lack of a better word. I'm sure a line array of the BMR's would fix that but I only bought three, not the required four for a series/parallel wiring scheme. No big deal, will see how it goes. Also, if the BMR was used (even in singles) for the front three, that would probably work as well as then all three would have the same power requirements. Even though it only takes an hour apiece to build these in temporary form I'm debating if it is worth further experimentation or not. ![]() Regardless, it has to be one of the best $10 speakers out there. |
#18 |
How about this.....
Do a 1.5 way. Wire 2 in series for a N impedance of 16 ohms, then put a cap on them where they fall in frequency.
I LIKE YOU
#19 |
#20 |
I bought a pair of these as well, I couldn't resist.
The dips are audible with a swept sine but not with music IMO. The way I understand it, the biggest dip at 1.8k as well as the stepped response in the upper end is a result of the bending mode radiator technology. I can't remember where but I read about them not too long ago in a book. I think the technology trades an even response for wide dispersion and can provide decent LF if designed for it. I'll see if I can find the info. -Matt |
| HiWave BMR drivers soon to be available from RS in the UK | sharpi31 | Parts | 1 | 16th October 2012 11:31 PM |
| New HiWave BMR 4" vs. Dyn 17WLQ | ro9397 | Multi-Way | 0 | 15th May 2012 10:47 PM |
| HiWave 2" BMR12 full range x4 + tweeter TBD | ro9397 | Multi-Way | 0 | 15th August 2011 12:54 AM |
| Wide range driver questions for xo.. | JandG | Multi-Way | 2 | 23rd October 2006 12:11 AM |
| help me choose a wide range driver | johnmark | Full Range | 38 | 26th June 2005 08:39 AM |
