What is the speaker for this number? 030510
Old 7th December 2012, 08:01 PM   #1
realflow100 is offline realflow100  United States
Default What is the speaker for this number? 030510
I searched on google for ages... I don't even see a single speaker in the search results!
My speaker is 10 watts 8 ohms
6 x 1 3/4 inches (very odd indeed)
Can someone figure out what this number means? It's on the back of the speaker magnet shielding 030510
Old 8th December 2012, 11:41 AM   #2
does anyone know?? o.O I wanted to figure out what speaker model it is so I can find a picture of it. but there is absolutely nothing on google!
Old 8th December 2012, 12:21 PM   #3
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
It's likely just a manufacturer serial number. With almost nothing else to go on, I suspect identifying it will be extremely difficult.
Old 8th December 2012, 01:31 PM   #4
ok umm.. the speaker is 6 x 2
8 ohms 10 watts
shouldn't there be a picture of something that's similar to that description?
Wait just found out It also has this labeled on it.
YDT516-A1
Searching on google still yields no results even resembling a speaker..
Okay After an hour of searching I finally found a Matching image of the speaker's I'm using.
http://www.sirenitas.lt/getImage.php...=YDT516-A1.jpg
They both came out of a old TV in a dumpster.
Both seem to be in brand new condition really clear sound quality
A slight amount of bass when in an open enclosure
running off a 400 watt amplifier (At very low volume so I don't hurt the speakers)
I have two matching speakers.. They are in a stereo configuration with my amplifier and my desktop computer.
What is your opinion on these speakers? I find they have a very odd dimension.. approximately 6" x 1" 3/4" but they do sound fairly clear and good sound quality.
Old 11th December 2012, 06:00 PM   #5
so I guess no one has any clue how these speakers would best sound?
ported enclosure? sealed? T-line?
Old 11th December 2012, 06:33 PM   #6
xrk971 is offline xrk971  United States
xrk971's Avatar
Make a flat wall mount transmission line like a hanging picture. See foamcore thread.
Easy and sounds good and low cost of materials to invest in. See post 16 in thread
Foam Core Board Speaker Enclosures?
Old 11th December 2012, 06:51 PM   #7
R.I.P.
It is a mass produced TV speaker. High Fs and high Qts designed
for effectively open baffle use in TV's, and probably the best way
of using them is very simple open baffles with boxed helper woofers.
They can't, won't and never will do proper bass in any arrangement.
rgds, sreten.
Old 11th December 2012, 10:21 PM   #8
not even in a 12 inch by 12 inch by 12 inch ported box (Or sealed box) made of 1/2 inch thick solid steel?
i know thats kinda silly to think of but it would be epic if someone made such a thing xD
Old 11th December 2012, 10:37 PM   #9
xrk971's Avatar
With a box like that you could use a nuclear powered driver to put out a megawatt of power.
Seriously, try a foamcore transmission line. Make a box about 20 in tall x 30 in wide and put dividers along 20 in direction to split into left and right channels and to double path to 40 in. Mount driver 1/3 from closed end, stuff 2/3 from closed end, make about 3 in deep. Wire it up and you will be surprised at how good it sounds. Doesn't take long at all. Make it out of foam core and the whole thing is a 2 hr project. See post 9 for picture.
Old 11th December 2012, 10:40 PM   #10
R.I.P.
They don't have the excursion in the bass. The parameters don't care
about any box once its above a certain small size. You can't reduce
the Fs of a driver with simple boxes, or reduce its Qts, they go up.
Any decent driver designed to work in such a box would be far better.
rgds, sreten.
What is the speaker for this number? 030510Hide this!Advertise here!
number of watts fakeout Full Range 4 2nd April 2012 03:51 AM
Copyright ©1999-2017 diyAudio
