I Feel Another Pair...
Old 5th December 2012, 07:55 PM   #21
cogitech is offline cogitech  Canada
cogitech's Avatar
Originally Posted by Nikola Krivorov View Post
What about an Alpair 7.3? Is there something in the specs that makes it not suitable for the Cornucopya?
I am just (slightly-educated) guessing, but I would think the A7.3 would be a better choice than the EL70. Perhaps better to ask about it in the other thread. Maybe someone already tried it with A7.3.
Old 5th December 2012, 08:12 PM   #22
chrisb is offline chrisb
The smaller Alpair metal cones aren't as likely to have the same "issue" with bass extension in such an enclosure as the EL70 might. If the design topology is one that is "scalable" to larger drivers, I wouldn't say the same for the Alp10.2
The only other downside I can foresee with a wide baffle wall mount would be the inability to toe-in to correct for HF directivity at various listening positions . This was certainly an issue with a local hi-fi shop's otherwise quite decent sounding OEM 2-way. I still have a pair recycled from my sister's living room reno of a few years ago.
kinda burnt out - taking a break
Old 5th December 2012, 08:13 PM   #23
Nikola Krivorov is offline Nikola Krivorov  Bulgaria
Mmmm, you are absolutely right, you were talking about trying new things with the EL70... apologies.
Old 5th December 2012, 08:27 PM   #24
cogitech's Avatar
Rubber or foam "feet" of appropriately different lengths could be attached to all four corners to force the frame to optimal toe-in and/or "toe-down" (depending mounting height, distance, etc). This is all assuming that the "frame' is hung with a flexible apparatus such as wire strung between 2 side-mounted eye hooks. Some bass extension from wall reinforcement might be lost in the process of moving one edge away from the wall, but it might be gained back on the opposite side of the "frame".
Old 11th January 2013, 08:18 PM   #25
cogitech's Avatar
Update:
I have decided that Cornus are a bit much for me at this point and I have veered off back in the direction from whence I came.
I have been looking at various of the suggested designs and I am considering either Wessex or Winderemere^2 in MTM configuration using ERT-26 and DaveR's MTM EL70/ERT-26 crossover.
Anyone ever done a Wessex or Windermere MTM?
Also, which digs lower, Wessex or Windermere^2 ?
(Needless to say, these will not be gifted to my Dad if I build them.)
I Feel Another Pair...Hide this!Advertise here!
Feel the bass? Riddles Subwoofers 23 3rd February 2012 04:50 AM
Should I feel guilty? theAnonymous1 The Lounge 13 31st January 2010 11:17 PM
ever feel like a ninja? theChris Everything Else 0 25th April 2003 05:33 AM
Copyright ©1999-2017 diyAudio
