Zen Acousta
Zen Acousta
Old 20th January 2013, 11:02 PM   #41
KoHo is offline KoHo  United States
EV Baronet!!!
Old 8th March 2013, 04:25 PM   #42
faithintruth is offline faithintruth  Canada
As others have commented, these speakers seems beautiful and different from other horns. I did think they were "Hedlund-ish" and was thinking of building the Hedlunds. I have FE206EN's (Qts .19) so I am intrigued by your design. The Acousta Horns look slightly simpler to build. In the video they are setup in free space so there is no corner loading and because they're hanging no floor contact. It's hard to discern the bass response...
Can you suggest how to modify the Fostex so that the back end of the magnet can exist outside the cabinet. How did you seal the back of the Lowther? Any other details would great.
BTW, when I tried to copy the image I got a picture of you come up....
Old 9th March 2013, 03:33 AM   #43
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Zen Acousta
Originally Posted by KoHo View Post
Hi, here my design, Zen Acousta.
Back loading horn with field coil Lowther drive.
My apologies for such a late entry. The speakers at BAF were extraordinarily
imaginative and beautiful.
Old 9th March 2013, 05:53 AM   #44
Hi Faithintruth
My Zen Acousta just combine with Hedlund horn and Lowther Acousta, the bass are deeper, faster and less coloration.
As the picture, my field coil magnet are huge, 5'1/2inch wide, I made a wood adaptor and use blanket to seal the gap.
For other driver, you may make a wood box to cover the magnet, like Lowther Acousta as picture show.
Thank for watching!
KoHo
Old 9th March 2013, 06:20 AM   #45
Default Hanging a soundboards
Very interesting simple testing about hanging a soundboards.
Finger tap, hanging are more frequency response than sitting on the floor.
Old 9th March 2013, 06:21 AM   #46
Thank you very much Nelson!!!
Are those wood phase plug working OK with your field coil magnet?
Old 9th March 2013, 06:52 AM   #47
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Thinking about suspending 'em ?
Which is different than hanging
( which is different also from a person holding something )
hint: 10 rubber bands per side , 5 at the top and 5 at the bottom , all attached to a frame may be bouncing a little ...
I should try the gum strips which are used for replacing the weights ( for bodybuilding...) in the stretch exercises .
Old 9th March 2013, 09:35 PM   #48
Another kind of Art Expression
Old 11th March 2013, 04:35 PM   #49
Hello Koho,
Thanks for explaining things a little more. I'm a little stuck on how the FE206EN will be stuck out the back. It's probably my inexperience, but the sound off the back of a speaker is important. Is the air coming off the back of the cone more important/useful...this part of your field coil is contained within the "compression chamber" area of the horn.
Thanks for the diagram from the original acousta horn. It clearly shows the magnet has an escape hatch below it which seems to indicate something valuable.
Still, I'd like to try this! If anyone out there has tried it with the FE206en please share!
Thanks, Sean
Old 12th March 2013, 03:24 AM   #50
Hello Koho,
Thanks, Sean
Hi
The depth of FE206En is 3"1/2
And the depth of Zen Acousta throat area is total 3"3/4 (drive section).
Look like just make a one piece of 1/2 ply to cover the magnet area hole.
Zen AcoustaHide this!Advertise here!
Accolade vs. Acousta ziocalepino Full Range 0 27th September 2011 07:53 PM
Acousta 116 plans ziocalepino Full Range 3 4th October 2010 09:17 AM
Acousta-stuf UK? keladrin Full Range 10 11th February 2008 02:38 PM
Acousta-stuf question Jiggity Subwoofers 6 5th August 2006 07:27 PM
Lowther Acousta info please! tater8 Full Range 4 18th December 2005 01:25 AM
