Old 29th November 2012, 08:44 PM   #11
cogitech's Avatar
Originally Posted by chrisb View Post
To address the original post's question - until I starting having issues with two different P/P EL84 amps that has since been quesstimated as bad rectifiers ( Sovtek 5AR4) and undersized fast blow fuse, I was driving my Castle / Towers with a Tubelab P/P ( Psvane 6BQ5 and 12AT7s- worth every penny as far as I'm concerned) at 12W and a DIY hack-job class A EL84 P/P at about 3.5W - neither ran out of juice for my needs.
I'll waffle a bit with the standard disclaimer "room/music/required SPLs" but I'd hazard a guess that if the MP301 is a real 6.5W of SE bliss, that'd quite probably be fine.
Yes. I would guess the same. My SPL requirements are not extreme.
Old 29th November 2012, 08:49 PM   #12
vinylkid58's Avatar
Originally Posted by cogitech View Post
I have pretty-much decided already to buy the Musical Paradise MP-301 MkIII, and I just wanted to run this by you knowledgeable folks to see if you think this amp would be a good match with my EL70 towers.
The extra headroom of a PP EL84 amp might come in handy. You could run in triode for casual listening.
Is it still "down for the count", or did you get it fixed up?
jeff
Old 29th November 2012, 11:07 PM   #13
chrisb is offline chrisb  Canada
jeff
Wonderboy was going to bench test again with proper fusing - this one's already been converted to SS rectification - the lack of voltage drop and turn-on surge is likely the culprit. Maybe some thermisters on the HT secondaries wouldn't hurt either - if it's good enough for Jim McShane & Eli Duttman's El Cheapo circuit.... .
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 29th November 2012, 11:39 PM   #14
vinylkid58's Avatar
Also good enough for Pete Millett. The DCPP amp has a CL140 right after the diodes for that very reason.
Another option would be to add SS diodes to the 5AR4 plates. That way you would benefit from the tubes voltage drop and not have to worry about reliability.
jeff
Old 30th November 2012, 01:07 AM   #15
cogitech's Avatar
jeff
Well, I am really only assuming that my SPL requirements are not extreme.
I am running my SPL meter right now with the volume as high as I reasonably ever might have it.
Listening to Adele (live, acoustic), 12 feet from the speakers, SPL hitting 98.6dB.
Will a small tube amp keep up?
EDIT:.....David Bowie just kicked in and this volume level is too much for me (or maybe it is the Raytheon tubes I just stuck in the B283). Anyway, peaks of 99-100 dB at 12 feet are about as extreme as I get. David Bowie (China Girl) hovering around 80dB peak at 12 feet is comfortably loud and very, very cohesive...
Old 30th November 2012, 01:33 AM   #16
cogitech's Avatar
Barenaked Ladies... and the Mullards are back in the B283. I just can"t do the Raytheons for very long. 85dB-ish peak at 12 feet is very comfortable with these tubes. Could probably push it more before it gets unpleasant.
Just trying to give you all a sense of my SPL expectations...
Old 30th November 2012, 03:37 AM   #17
vinylkid58's Avatar
Not a chance at that distance. At those levels, your Yamaha is probably getting close to it's rated output.
At that level, a small amp would be fine. You'd only need a couple of watts. Bump that up to 90dB, and you'll need 16 watts to produce that peak. Every 3dB increase, you'll need to double the power.
It sounds like your B283 buffer is adding a lot of distortion.
jeff
Old 30th November 2012, 03:45 AM   #18
frugal-phile(tm)
planet10's Avatar
A quick back of the hand calc, and giving some benefit to the doubt to room gain, the Yamaha is clipping at those levels.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th November 2012, 03:54 AM   #19
vinylkid58's Avatar
You're right, but I was trying to be generous.
BTW Dave, Ken dropped by today and picked up your MarKels.
jeff
Old 30th November 2012, 03:58 AM   #20
frugal-phile(tm)
planet10's Avatar
He phoned me so i knew that... thanx.
dave
CSS EL70 & CHP-70 Comparison KyleinCowichan Full Range 91 10th January 2013 09:39 PM
EL70? GratefulTony Full Range 46 3rd December 2012 07:08 AM
El70 in Pensil? type Full Range 12 11th September 2010 07:41 PM
CSS FR125S, Alpair 7 & CSS EL70? Monte Verdi Markaudio 6 29th June 2010 08:51 PM
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 04:14 PM
Copyright ©1999-2013 diyAudio
