Hi all, I'm putting together something similar to the 4" cube PC Speakers done by Wolf as one of my first projects.
It uses the Aurasound NS3-193-8A in line with a 500uF cap. What I'm struggling to understand is the purpose of the cap. From what I know, its acting as a high pass that has a cutoff frequency of ~40hz.. what is the benefits of that? |
#2 |
frugal-phile(tm)
Personally i am not a fan of an in-line cap on a sealed box. AFAIK it is to flatten the response of a too-small box. If i was faced with too small a box i'd make it aperiodic.
Since i am averse to electrolytics, the film caps to do 500 uF would be way more expensive than the driver, and take up as much space as the box. My NS3 were in about a 1.5 litre box, they worked fine. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 | |
The response of your 1.5L NS3 was acceptable without a filter? Would this be an aperiodic or a sealed box that you put them in? |
#4 |
frugal-phile(tm)
Performance was acceptable. Bass is one thing the NS3 has no lack of (for a 3")
The box is sealed. dave
#5 |
Yup, scrap the cap. Especially if your computer is your source.
#6 |
There is nothing wrong with the principle on an inline capacitor for sealed. It works well if done properly but its severely not fashionable. For a FR you should be looking at a capacitor consisting of multiple parallel types, and I'm not going to suggest values and types, only to be pointlessly argued with by a bunch of component fascists. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#7 |
haha!
awesome. ![]() (I mean....brilliant)
I LIKE YOU
#8 |
Hi Streten, my current two way has 5 caps in it. I'm far from a component fascist. But how does putting a cap in series help this system? It's hooked up to a computer. If he needs the high pass, the computer can do it. If he needs bass boost, the computer can do it. The computer can do anything a cap can.
#9 |
You can model it in the demo version of Basta!. Here is one implementation explaining the principles : http://www.humblehomemadehifi.com/do...20Box_copy.pdf The fairly high Qts NS3 should be ideal for the technique. Note that the capacitor improves the bass response and adds some subsonic filtering which is always going to be useful with such a tiny driver, even with AV fitering. An interesting option is a single rail power amplifier and making the speaker capacitor also the amplifier output coupling cap. rgds, sreten.
| Opinions on pc/mobo "onboard spdif to Ian's FIFO kit" or "USB to WaveIO" to I2s? | edbk | PC Based | 0 | 1st May 2012 02:40 PM |
| FS: Peerless 8" 835026, peeless 3" concentric, aura ns3-194, etc | durwood | Swap Meet | 10 | 6th December 2011 12:30 PM |
| 70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. | facundonu | Multi-Way | 34 | 9th March 2009 04:59 AM |
| Anyone used Aurasound 3" NS3 widerange? | morbo | Multi-Way | 15 | 19th October 2004 12:07 AM |
