My first build, Ideas on a Horn/TL full range?
Old 27th November 2012, 04:07 PM   #1
malovich is offline malovich  United States
Default My first build, Ideas on a Horn/TL full range?
I guess like many i got sucked into the $100 limit of Parts Express for free shipping, I was taking advantage of the Cyber Monday deals and needed $35 more bucks to get it. I threw a pair of ND91-8 drivers on my order as I've always wanted to try a full range speaker. Yes I know this may not be an ideal driver but oh well, I don't have finely tuned ears or a perfect listening environment either.
What would be a half decent design for these if I were to split the difference between efficiency and bass assuming I'll have a decent enough amp and I never listen at reference (yet). Floorstanding is preferred at~40-45" tall or so with a front port (not enough room anywhere to bring these away from the wall). I also like the look of the extra tall curvy chang speakers but I feel they may look odd to be so tall and skinny with this smallish driver.
Alternatively a soundbar type setup in stereo would be cool. Would putting the "ports" (is the correct term front or rear loaded in this case?) in the middle beside eachother pose a problem? The ports are just for low frequency non-directional sound anyways correct?
Old 27th November 2012, 06:28 PM   #2
zman01 is offline zman01  Bangladesh
Check out the TABAQ TL thread
Old 27th November 2012, 07:11 PM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
THis driver is an OEM variation on the Aura NS3. Listed specs are quite different thou. Character thru the mid/top should be similar thou.
It really needs examining from 1st prinicipals instead of trying to shoehorn it into a box designed for another driver.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th November 2012, 07:21 PM   #4
dave
In that case what should I be looking at? Yes I created my profile in 2007, 5 years ago but I have only lived vicariously through you guys. Since experience is king I am a mere peasant around these parts.
Some of the TABAQ variations look like they would work for a sound bar interestingly, even if they aren't optimal. I do have a BS in Mechanical Engineering so don't go easy on me.
Old 27th November 2012, 07:29 PM   #5
frugal-phile(tm)
planet10's Avatar
Grab some modeling software (on 'puter or on-line) and do some sims to get an idea how the driver responds to the box... you'll learn a lot just looking at the graphed results.
One criteria i use for BR response is that i avoid any situation where the 1st derivative of the FR curve crosses zero more than once (ignoring the flat-part of the curve in the HF)
dave
Old 27th November 2012, 09:01 PM   #6
chrisb is offline chrisb
dave
you'll probably be needing to explain or graphically annotate that again - it's not clear to a lot of folks, and likely most certainly those at the front end of their learning curve.
kinda burnt out - taking a break
Old 27th November 2012, 11:56 PM   #7
frugal-phile(tm)
planet10's Avatar
dave
My first build, Ideas on a Horn/TL full range?Hide this!Advertise here!
12" full range on a backloaded horn, BIB, tappered quarter wave or other horn boxes? c3conv Full Range 1 27th July 2011 06:37 PM
Back Loaded Horn (BLH) Full Range Speaker Build jgray Full Range 10 6th June 2011 04:25 AM
Filtering a full range compound horn? brsanko Full Range 21 29th March 2009 06:16 PM
my full range horn audiofilofine Full Range 2 2nd July 2007 03:19 PM
Cheap full range drivers in the u.k. Any ideas? filholder Full Range 6 9th December 2006 09:42 PM
