Alpair 12P Open Baffle/U-Frame with 8" sealed woofer. Passive Cross Over. Pictures - Page 3 - diyAudio
Old 23rd December 2012, 12:54 AM   #21
TiMBoZ is offline TiMBoZ  Australia
Ok then, just clear this up for me - if there's no correlation between relative impedances and output volumes in the same circuit. How does a resistor on the input, attenuate a driver relative to another driver?
Old 23rd December 2012, 02:40 AM   #22
Design is wandering; slapping tweeter up top without due consideration and measurements is shooting blind.
OB forced close to wall begs undesirable early reflections.
Low order cross with 8" woofer at wide baffle spacing produces highly lobed response.
Speaker doubtless sounds best with 12P solo, and this is doubtlessly thin.
So the resistor value will just be to 'taste' by ear. Sound ok?
Without measurements and design tools it is all to 'taste' by ear, and will be OK, until you tire of how the speaker is stamping it's sound on everything played through it.
Within designed full range application and appropriate box type enclosure to augment/support lower end driver has potential to sound very good.
OB is tough territory for ultra light weigh, shallow depth diaphragm.
Good luck
Old 23rd December 2012, 02:48 AM   #23
I've had a bit of a ponder on this: essentially your saying at 20Khz the sensitivities of each driver is at maximum. The 10 Ohm tweeter is at 92db and 15 Ohm A12 is at 89db from spec sheet. That the impedance difference between drivers is irrelevant? Correct?This is simple enough I guess. But I'm not convinced it's as simple as that, just yet.
Have a think about how 8 Ohm and 4 Ohm, but otherwise identical woofers, the 4 Ohm version is nominally 2-3db more efficient.
Also note: the resistor value I've settled on for now is 5.6 Ohms. I didn't calculate this. I started with a 3.3, went up to a 4.7, then to a 5.6. Now it just so happens we have both drivers at roughly 15 Ohms don't we?
What about looking at a single driver. The driver is generally loudest, most efficient where the impedance is lowest. Your contention suggests that resistors are really only to correct for a 'sensitivity' imbalance between drivers. But what causes the imbalance? It isn't just 'efficiency'. I reckon somewhere there's an equation/formula to calculate for this. But my maths is terrible.
Old 23rd December 2012, 03:14 AM   #24
tuxedocivic's Avatar
The resistor in series increases the impedance of that driver, thus reducing current to that driver. The resistor in parallel divides the current. So less power goes to the driver.
Old 23rd December 2012, 03:15 AM   #25
This is true enough. Some of this is subjective, I guess this is just a fundamental con of OB generally. On the plus, It gives a very live, present, engaging presentation. Everything sounds good. I'm cool with that, for now.
The 'fullness' or fatness of it is much better than I was expecting.
When I get tired of it, I'll just swap it over to something else. Some other 'boxed' project. I don't take it that seriously.
Old 23rd December 2012, 03:20 AM   #26
Didn't notice your last post. It is as simple as your first paragraph.
The 4 vs 8 ohm. They are 3db apart at 2.83V, but they are the same at 1 watt. That's the catch. One is not free SPL.
Your example of resistor choice is just a fluke, and not even valid without measurements.
Your last point about being loudest at the drivers lowest impedance is also not really true. Look at how effecient a woofer is at Fs. Or way up in the breakup region.
Have fun. I can't keep going on about this.
Old 23rd December 2012, 03:59 AM   #27
Cons of OB are need for high linear excursion and EQ for flat response; pros are much less baffle resonance, and no re-radiation of sound reflected in box, no energy storage in ports. These pros are some of the elements that make OB engaging, even without EQ and optimal baffle.
'by fanatics, for fanatics' and all levels of interest.
Enjoy!
Old 23rd December 2012, 11:36 AM   #28
chris661's Avatar
You could get somewhat more bass by adding a series resistor to the Alpair (ie, make it properly full-range).
This might seem counter-intuitive, but the reasoning goes as follows:
- around Fs, the impedance of the speaker increases.
- a series resistor acts as a potential divider
- at Fs, the speaker sees much more voltage than at other frequencies, so the amount of power it gets in the LF region also increases (compared to the rest of the frequency range), so you get a bass boost at Fs, but not below (where excursion would be large due to the very low frequencies)
Try resistor values of 1ohm to 4r7.
Yes, you lose some power in the resistor, but in a home hifi situation, it won't be much.
Old 23rd December 2012, 08:43 PM   #29
You could get somewhat more bass by adding a series resistor to the Alpair (ie, make it properly full-range).Try resistor values of 1ohm to 4r7.
Thank you for the suggestion/idea Chris661. I might try that, just as a temporary experiment. Report my findings. I'm not too keen on series resistors they are a necessary evil. IMO They have a side effect: they suppress micro dynamics. With the woofer engaged bass (lack of) isn't an issue. The full/fat-ness from A12 on it's own is surprisingly satisfying. It's good for me to be have a lean sounding option. The reduced bass impact is more comfortable for me in regard to my neighbours. I can get more use out of my system: watch TV less and listen to music more.
Old 24th December 2012, 12:22 AM   #30
Ahhaaaaa! I THINK I can see what tuxedocivic was trying to explain to me. Voltage and wattage are different. Voltage can remain constant while wattage consumed by driver/supplied by amp will vary according to driver impedance. So an imbalance between drivers in watts doesn't mean an imbalance in output volume. I THINK. I was getting confused by a calculator I was using.
Assuming 2.83 = 1 watt at (x) Ohms
At 20Khz amp sees 6 Ohms from 2 x drivers in parallel. At 20 Khz the A12 is 15 Ohms and 89 db efficient. Uses 0.4 watt. At 20Khz the tweeter is 10 Ohms and 92db efficient. Uses 0.6 watt. We still can assume 1 volt input/output. Volume is related to input voltage. Watts is related to power consumed to achieve a given output/voltage.
Apologies for my noob/boof-headedness
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Full Range 58 3rd November 2015 03:07 AM
open baffle for alpair 12p murphythecat8 Full Range 5 25th October 2012 10:40 PM
Modelling a semi-open-baffle in WinISD for use with a sealed-box woofer? Spasticteapot Multi-Way 2 27th November 2006 10:49 PM
DIY Open baffle / Sealed woofer design preiter Multi-Way 11 25th August 2006 06:31 PM
FS: 8.4" and 12.1" Open Frame LCD [Michigan] (Warning: Large Pictures) ry.david Swap Meet 0 8th July 2006 01:14 AM
Copyright 1999-2017 diyAudio
