Alpair 12P Open Baffle/U-Frame with 8" sealed woofer. Passive Cross Over. Pictures
Old 14th January 2013, 06:06 AM   #31
TiMBoZ is offline TiMBoZ  Australia
Update: A12P running without any filtering. For a reference/example of how low the A12P plays: take the Massive Attack track 'Angel' which has this intro that has a kick drum and click beat with a low, pulsing rumble (bass guitar detuned I think). You can clearly hear the upper 30 - 40% of this rumble through the A12. I was surprised! Fiddling with 2nd order filters on the woofer and super-tweeter. I believe this should give me 180 degrees phase against the unfiltered A12, no reverse polarities.
Old 20th January 2013, 05:52 AM   #32
Monte Verdi is offline Monte Verdi  United States
Monte Verdi's Avatar
Timboz, Excellent, I'm a true believer as many know that if you can eliminate crossover parts in the chain the purity of the signal has a clarity that is unbelievable. This driver allows me to have an entirely separate subwoofer set up out of the way of the 12P's with a crossover point well out of the way of any critical area, truly seamless. Timboz, your correct in your assessment, the mid low strength of this driver is astounding. Although I must admit I have not felt the need to add a tweeter, quite happy with the extension, quite natural to my ears. Btw, I run OB configuration as well, and it's magical!
Old 27th February 2013, 12:24 AM   #33
I recently played some MP3 sine waves (via iPod quickly flicking from to to another) at intervals of 10Hz at a fixed, fairly modest listening volume. I can't measure, only listen. I also have a XLBaffle 'sim' and now I can say that the sim actually seems pretty accurate, from what I can gather.
In it's current baffle set-up the A12P (no filtering) starts to roll off at 6db (I think) from around 250Hz, maybe a bit lower. A12 is just audible at around 70Hz. But barely audible at all by 60 - 50Hz. It's still useful/handy for quiet listening sessions by itself.
The woofer in sealed box plays audibly, 'usefully' down to about 60Hz or so. Not as low as I was hoping.
The output from woofer will overlap the output of the A12 at around 120 Hz judging by the sim. But I might aim the XO a bit higher to keep the values of inductors as small as possible. Maybe a 2nd or 3rd order at 150Hz kind of thing.
Old 8th January 2017, 03:01 AM   #34
MITsound is offline MITsound  Canada
MITsound's Avatar
Default If anyone is still there
I've repurposed my Onken style cabinets for distributed mono bass, and put my 12P pair on small, stand mounted open baffles.
And I was unable to resolve hum issues from some pro audio active crossovers, so I'm now wiring things without a passive crossover, but using the digital crossover in a factory refurbished Arcam Diva AVP 700 digital processor.
(A pleasant surprise- must be a new chip, as it handles new bluray audio formats).
Anyways, this preamp has a excellent digital crossover, with at 40-130 hertz points, time alignment adjustable on the fly, by ear, for each speaker and sub.
It's also a very good sounding DAC, and was available for CDN $329 , free delivery, and a 12 month warrantee.
Life is much easier with this built in active crossover, and it turns out corner loaded Onkens with 15 inch woofers, and between the stereo 12Ps, a push pull pair of W frame 18 inch subwoofers/tv stand, produces punchy, pitch clear, bass , which easily blends with the Markaudio pair.
Couldn't be happier with this solution for an integrated DAC, 2.1 channel home theatre processor, bass management, preamp .
Oh, it also has digital bass and treble controls (defeatable) individually, for each channel.
Just saying, this sort of thing can put a lot of easy love back in your music projects.
On the other hand, my point is still moot.
Last edited by MITsound; 8th January 2017 at 03:04 AM. Reason: Autocorrect changed w frame to women frame.
Alpair 12P Open Baffle/U-Frame with 8" sealed woofer. Passive Cross Over. PicturesHide this!Advertise here!
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Full Range 58 3rd November 2015 02:07 AM
open baffle for alpair 12p murphythecat8 Full Range 5 25th October 2012 09:40 PM
Modelling a semi-open-baffle in WinISD for use with a sealed-box woofer? Spasticteapot Multi-Way 2 27th November 2006 09:49 PM
DIY Open baffle / Sealed woofer design preiter Multi-Way 11 25th August 2006 05:31 PM
FS: 8.4" and 12.1" Open Frame LCD [Michigan] (Warning: Large Pictures) ry.david Swap Meet 0 8th July 2006 12:14 AM
Copyright ©1999-2017 diyAudio
