#11 |
That would complicate the build somewhat - you would need a crossover, and also need to build a cabinet to isolate the woofers from the mid-range.
#12 |
would two 6" fullrange sound good?
#13 |
#14 |
so what would sound good in a small cabnet?
its not that small, its 14x8x7 ...any ideas? |
#15 |
Larryldspkr suggested the CHR-70.3 -should work within the constraints you have. The bass champ when it comes to small FR drivers is the EL-70. Probably no longer available at CSS - you need to write to Planet10 to see if he has stock. This will need slightly bigger cabinets vs CHR-70.3.
But again, stuff like dubstep at loud volumes can stress a FR driver (specially a small one), and lead to driver over excursion if not careful. Or you can go 2 way - small mid-bass like this might work mated with a tweeter: Dayton Audio ND105-4 4" Aluminum Cone Midbass Driver 4 Ohm 290-212 There is an 8 ohm version of this driver too. No experience with these - so can't really say if good or bad. |
#16 | |
for dubstep, you could use a FR abut you need to add stereo subs to fill in the bass. you will get good sound IMO, no matter what 4 inch, you will miss the bass, better either add subs or you could simply build a known two-way design with a 6 inch midbass a 1 inch dome tweeter. but then again, you wont have 30 hz response, stereo subs would. |
#17 |
6"fullrange going to be any better?Would 2 midrange and 1 tweeter work well...what are some good tweeter and midranges?
Will the tweeter and mid ranges hook up to the lepai 2020? If so, how? Thanks for all your patience, im still trying to figure this stuff out
#18 |
I want to get atleast two speakers in it... i was looking at some diy boomboxes (on google) and they put in two... how?
#19 |
Step up to the Mark Audio Alpair 10.2, they could work in that size enclosure! More expensive but killer bass as good as or better than most woofers that size! Also no need for a tweeter or crossover, so a simple solution. They take a little while to break in but a little patience will be well rewarded. BTW these are 5.25 inch drivers, well worth the extra cost!
Larry |
#20 |
Will two of the speakers work in the enclosure? I want two so it will look boombox ish and be louder…
| Quickie woodworking question! With bonus shellac question... | head_unit | Construction Tips | 13 | 12th September 2010 05:38 PM |
| do i REALLY need a crossover?? and an amp question. and an ohm question | legendaryfrog | Multi-Way | 4 | 29th October 2006 01:39 AM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| Capacitor Question /question on cap | TunaFish | Tubes / Valves | 14 | 12th January 2004 02:23 AM |
| Page generated in 0.08566 seconds (100.00% PHP - 0% MySQL) with 9 queries |
