The Supernova! (a full range flooder line source)
Old 15th December 2012, 01:17 AM   #121
soundaatma is offline soundaatma  United States
Hi Melotheory,
Did you consider a dipole full range line array, on a really thin 4" OB, with about 20 of your 3" FR drivers on one side, equalised flat to 80-100Hz and high passed 80-100Hz, with separate monopole/dipole active bass unit. It could offer all the polar benefits of a dipole, no box as opposed to omni, but likely greater image depth than the omni
Old 15th December 2012, 01:49 AM   #122
Melo theory is offline Melo theory  United States
Melo theory's Avatar
Hey Joy....
To me, line sources are about dynamics and front row concert presentation.
I actually had these drivers in a focused dipole array. It's the "Event Horizon" thread.
The only way I would do a 4" wide dipole would be in a 7' tall focussed array. And I may do that some day.
I just want to finish this one as an omni, then I'll move on to the next obsession
I LIKE YOU
Old 15th December 2012, 02:02 PM   #123
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by Melo theory View Post
But I would also be the first to try an omni line array!
Not really, Beveridge had products as omni line arrays already very long time ago. They were half space omnis placed on the side walls.
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 15th December 2012, 02:06 PM   #124
You sure are a lucky man to pursue your hobby unbound !!
Is the ambio processor good for both monopoles and dipoles in combining stereo signals.
Old 15th December 2012, 03:05 PM   #125
Yeah but they were not full range driver omni's using acoustic reflectors. That was the whole point of these, to see if it helped with CTC spacing comb filtering.
I LIKE YOU
Old 15th December 2012, 03:17 PM   #126
Well, it definitely works great with dipoles and with any type in the near field.
You just need to be careful of reflections in the far field. I'm still investigating. On this flooder, it doesn't really help or hurt it. It sounds like you are in well either way
But, I tell ya......its far superior to stereo when set up correctly.
I LIKE YOU
Old 16th December 2012, 11:16 AM   #127
Elias's Avatar
But, I will give matrixed a try with single drivers first, then with the array if it works out.
You may also like to try the matrix with 3 separate speakers. It depends less on the room geometry than single speaker stereo SSS.
Old 16th December 2012, 09:10 PM   #128
How are you tackling comb filtering issues on the array, or are they too insignificant with such small drivers.
Old 16th December 2012, 09:55 PM   #129
I'm going to use acoustic reflectors pictured here in the first post.
http://www.diyaudio.com/forums/full-...ine-array.html
I LIKE YOU
Old 17th December 2012, 09:13 AM   #130
Colin is offline Colin  United Kingdom
If you want to know the excursion/dB output vs low frequency limits of any given driver or number of drivers, this online calculator is useful
Piston Excursion calculator
The Supernova! (a full range flooder line source)Hide this!Advertise here!
Full range line array inrank Full Range 43 16th November 2017 07:25 AM
Need T-Line help for Full Range T-Line wanton Full Range 35 11th November 2012 07:37 PM
Source for full-range drivers for DJ headphone project? jkantor Headphone Systems 0 24th June 2011 02:08 AM
Dayton Point Source Full-Range Neo Drivers bluegti Full Range 2 13th November 2010 06:49 AM
Full-range line array? mazeroth Full Range 20 1st November 2004 03:47 PM
