The Supernova! (a full range flooder line source)
Old 13th December 2012, 11:25 PM   #111
Melo theory is offline Melo theory  United States
Melo theory's Avatar
Hey Jon...
in Ralph's set up, those surround speakers are for synthesized hall ambiance.
With the matrix approach, what comes out of sides vs. center is frequency dependent.
all high frequencies come from the sides but the mids and low-mids come from center.
Thats why I don't understand Elias' explanation about it being ok to have a delay, The only thing that gets delayed is high frequencies and I don't think it matters whether it comes from the center in the mix or the side, All high frequencies will come from the sides with a delay.
Also, I think this would give a rather large presentation of center images. They would seem as wide as your walls are.
Of course i'm not sure how this all works out psychoacoustically, which is why i'm willing to try it, just not with 25 more drivers.
I LIKE YOU
Old 13th December 2012, 11:29 PM   #112
I do trust that Elias knows what he is talking about, he is one of the few here that is willing to reach beyond the old idea that stereo is good enough.....i'm just running through it with mental rational.
I LIKE YOU
Old 14th December 2012, 01:32 AM   #113
norman bates is offline norman bates  United States
norman bates's Avatar
I don't know.
But you might !!!!!
The slight delay due to left/right taking longer to hit the wall then get to your ear (compared to the center speaker) may not be offensive to the ears. Your ears might even like it better than all of it hitting your ears at the same time. And who knows how far out a left image will place.
We like our music's echos to match our room. To me by involving the room more, your ears have an easier time saying "yes, that's what it would sound like in this room". Zero reflections are nice, but when I tried 6" of foam on both side walls, the room was so dead, the music sounded worse.
I think the flooder plus center would be better than stereo triangle, but I doubt it would be better than the divider (man I loved the sound). And I think the RACE would be close to as good as the divider.
And new news on your binaural ?
Norman
Old 14th December 2012, 05:16 AM   #114
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Originally Posted by Elias View Post
Ah. I was talking about that thread. My mistake, again, I thought that was an active design requiring small delays. I really should pay attention
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 14th December 2012, 09:11 AM   #115
Elias is offline Elias  Finland
Elias's Avatar
Earlier I was suggesting this having 3 lines, since you have 50 drivers:
You could put 16+16+16 drivers into a SSS matrix
No need for a BSC.
But you were seeing nightmares
Originally Posted by Melo theory View Post
That sounds like a wiring nightmare
I was just going to put the mini-ambio on it.
But you can convince me of the matrix approach if you want
I'm not experienced with it.
So here I'm trying to convince
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 14th December 2012, 01:34 PM   #116
Haha!
I actually did have a nightmare about wiring that SOB!
You suggested I do that, yes......but then you never responded.
Now that I've built the durn thing, you are trying to convince me!
Why I aughta......(I'm shaking my fist)
I LIKE YOU
Old 14th December 2012, 01:50 PM   #117
von Ah is offline von Ah  United States
von Ah's Avatar
So are you considering chopping off one end of the 'Lith in order to make the 3x16? You could use the remaining two drivers for a foamcore Cornu.
Old 14th December 2012, 05:40 PM   #118
Yes, I know about that foam core build, and as interesting and innovative as it is.......I don't really care for BLH's.
But maybe someday. I have a bunch of projects going on right now.
I LIKE YOU
Old 14th December 2012, 07:45 PM   #119
Elias's Avatar
Haha!
You could be the first on this planet to try matrixed line array. Glory be to the brave
Old 14th December 2012, 09:05 PM   #120
But I would also be the first to try an omni line array!
Which was my plan from the beginning
But, I will give matrixed a try with single drivers first, then with the array if it works out.
I LIKE YOU
The Supernova! (a full range flooder line source)Hide this!Advertise here!
Need T-Line help for Full Range T-Line wanton Full Range 35 11th November 2012 07:37 PM
Source for full-range drivers for DJ headphone project? jkantor Headphone Systems 0 24th June 2011 02:08 AM
Dayton Point Source Full-Range Neo Drivers bluegti Full Range 2 13th November 2010 06:49 AM
Full range line array inrank Full Range 39 20th January 2009 12:27 PM
Full-range line array? mazeroth Full Range 20 1st November 2004 03:47 PM
Copyright ©1999-2017 diyAudio
