The Supernova! (a full range flooder line source) - Page 9 - diyAudio
Old 10th December 2012, 07:36 AM   #81
Melo theory's Avatar
What, put a row of drivers down the middle?
And sum right and left to center?
I LIKE YOU
Old 10th December 2012, 07:41 AM   #82
Originally Posted by xrk971 View Post
What do you do to it to make it an omni? It's too bad that it doesn't do what you thought it would do. I still like it...
Well, I kinda knew this flooder wouldn't work out, so I made it a certain way to be able to add a row of acoustic reflector lenses. You'll see.
I LIKE YOU
Old 10th December 2012, 10:15 AM   #83
CLS is offline CLS  Taiwan
Originally Posted by Melo theory View Post
The problem is that there is no direct response from about 3kHz and up...only reflected.
No direct sound above 3kHz is a situation.
What exactly is the problem?
Old 10th December 2012, 10:54 AM   #84
mondogenerator's Avatar
a side firing L and R flooder with C for direct cues, adjustable in volume and delay, in a single box would be an interesting concept. I.e. I like the idea better than Elias' single box stereo speaker. Of course that project may have changed.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 10th December 2012, 02:25 PM   #85
xrk971 is offline xrk971  United States
xrk971's Avatar
Flip the front baffles around so the 45 deg is toed-in.
Old 10th December 2012, 05:17 PM   #86
norman bates's Avatar
yea, but then you'd need more drivers.....
It would be like mini ambio without the extreme panning.
It may not work, who knows.
Norman
Old 10th December 2012, 06:33 PM   #87
Well......it sounds like I'm in a sewer pipe!
I'm thinking direct sound should reach the ears first. Then reflected.
I LIKE YOU
Old 10th December 2012, 06:41 PM   #88
Norman
I'm sure it won't work. Although I was suprised on how much sound was coming from the sides. But it was only high frequencies so it sounded disjointed. A plus was that I was able to cut off RACE at around 1-2kHz
If I went with the matrixed center, that wouldn't help to push mid frequencies to the sides. I would still have to apply RACE and I'm not sure of the effect of that on a mono center....it may not hurt it. But the center still would not do much for the delay of HF coming from the sides.
Also, with the omni design.....it would alleviate CTC CF
I LIKE YOU
Old 10th December 2012, 06:48 PM   #89
Yes, it might just come to that
Split it down the middle and go with traditional stereo set up.
I don't think line sources are good for critical listening anyhow.
I LIKE YOU
Old 10th December 2012, 06:56 PM   #90
Well I guess the difference would be the adjustable delay? Oh and this one has the side drivers at 45 degrees.
I'm sure Elias flooder is good. I think the problem with this is that it's a line source and it's nearly equally as loud coming off the wall because of the cylindrical wave front, add comb filtering to that and the fact that line sources swamp the room, and you have yourself a perfectly constructed sewer pipe!
I LIKE YOU
Need T-Line help for Full Range T-Line wanton Full Range 35 11th November 2012 08:37 PM
Source for full-range drivers for DJ headphone project? jkantor Headphone Systems 0 24th June 2011 03:08 AM
Dayton Point Source Full-Range Neo Drivers bluegti Full Range 2 13th November 2010 07:49 AM
Full range line array inrank Full Range 39 20th January 2009 01:27 PM
Full-range line array? mazeroth Full Range 20 1st November 2004 04:47 PM
Copyright 1999-2017 diyAudio
