The Supernova! (a full range flooder line source) - Page 11 - diyAudio
Old 13th December 2012, 07:26 PM   #101
mondogenerator's Avatar
Originally Posted by norman bates View Post
you can always try the left speaker, summed left + right speaker, and right speaker.
Just use 3 drivers and play with levels, play with a squeek of delay.
Yes race won't be there, but it gives a solid center and a panned left/right, versus a diffuse center.
Norman
This is what I meant, but instead I said L-C-R... Although that could work for a soundbar type thing. I like this idea, just for the simplicity. Elias' your methods seem good, up to the point where my understanding of the subject falls short. I guess id just like a simple passive system.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 13th December 2012, 07:36 PM   #102
Elias is offline Elias  Finland
Elias's Avatar
Really ? Then you should try this
Elias Pekonen Home Page - Stereophonic Sound from a Single Speaker
- Elias
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 13th December 2012, 07:38 PM   #103
Melo theory's Avatar
Originally Posted by Elias View Post
Yes exactly there is no way to steer the midrange freqs by only using 2 drivers. You'll need 3 drivers and the matrix. Then only a vector is formulated which can be steered by the stereo panning.
- Elias
Ok, do I delay the summed center to achieve time coherence with the L+R?
And will this configuration solve the way to diffused soundfield?
I would hate to invest in 25 more drivers and be disappointed.
Of course if I delay center than it would only be in phase with the reflected HF.
I LIKE YOU
Old 13th December 2012, 08:14 PM   #104
norman bates's Avatar
uhhhhh.
Try it with something else instead of buying more drivers.
Maybe 3 cheapie but exactly the same speaker (2-way, whatever).
And yes, the center speaker may be moved back.
Norman
Old 13th December 2012, 08:21 PM   #105
Elias's Avatar
Time to ask yourself a question: Why a side image would need to be in time coherence with a center image ?
In the original sound event they are not in time coherence, unless all the performers are located in a circular arch surrounding you which is highly unlikely.
Old 13th December 2012, 08:28 PM   #106
I'm not sure about this one Elias.
If it's a live recording and there are spot mic's across the stage then I see your point.
If it's a 2 mic recording or M/S of a live event then that time difference is already accounted for.
Studio recordings, well. They are usually close mic'd. So, the drums are always across the whole stage as well as piano. I guess any large instrument takes up the whole stage if close mic'd.
Also with matrix aren't center sounds coming through R+L also?
I LIKE YOU
Old 13th December 2012, 08:47 PM   #107
Elias's Avatar
R+L is the center signal in a linear matrix.
Old 13th December 2012, 10:09 PM   #108
I know, I meant what is mixed to center.
I LIKE YOU
Old 13th December 2012, 10:12 PM   #109
Alright, tall ya what.....
I will build a prototype out of single drivers before I invest in a line.
I LIKE YOU
Old 13th December 2012, 11:10 PM   #110
sure, but...........
3 x 3.5" may not cut it.
Maybe 4 x 3" per line (left, center, right), that be what, Sd = 6.5" ?
That way you don't have to buy any more drivers
I'm not really sure.
I see that a delay may be fine for the sides (maybe 3-4mS) versus the straight direct center sound.
But you are right, it should already be mixed in.
Didn't Ralph from ambiophonics have all sorts of speakers around then you set delays based on what hall you wanted to be in ?
Who knows.
But I do know that 3 loudspeakers across the front with center as L+R, was commented on being able to turn your head a bit to zoom in on different things, like a cocktail party zooming in on different conversations. I have zero experience, but I do trust the ears that said that.
Passive L+R is tricky because of changing impedences.
But as I learned from Home Theater, have the exact same speaker left, center and right, and ideally the rears same as the front if you can swing it.
Norman
Need T-Line help for Full Range T-Line wanton Full Range 35 11th November 2012 07:37 PM
Source for full-range drivers for DJ headphone project? jkantor Headphone Systems 0 24th June 2011 02:08 AM
Dayton Point Source Full-Range Neo Drivers bluegti Full Range 2 13th November 2010 06:49 AM
Full range line array inrank Full Range 39 20th January 2009 12:27 PM
Full-range line array? mazeroth Full Range 20 1st November 2004 03:47 PM
Copyright 1999-2017 diyAudio
