Assuming the internal volume of a speaker enclosure is correct for a particular driver how important is the actual shape of the box?
#2 |
Have you read this thread?
Best sealed enclosure for completely supressing back wave Or this one? Box colourations - really ? Maybe this one? Sealed enclosure -- golden ratio? I mean.....there are a lot of threads covering this. But to sum it up, it depends on the BW of the driver. You just have to be careful of standing waves. Also, some shapes suppress vibrations better. Like round or egg shaped
I LIKE YOU
#3 |
Thanks Melo. I'll check out those threads.
#4 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 | |
IOW, at some point quarter wave action will predominate - which becomes a critical factor in the design of non sealed enclosures. Something else to consider is internal depth - I've had experiences with several wide and shallow designs that exhibited colorations most notable in the vocal range not present in enclosures with different aspect ratios - even those much smaller in overall volume.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#6 |
Oh yes, I was assuming sealed enclosures.
I thought it might be obvious that the shape of vented enclosures will effect performance. IE. the TL or ML or BLH types. I should have gave a mention to BR's. Thanx Dave.
I LIKE YOU
#7 | |
ah yes, when one a$$ u me s Even with sealed, I'd still try to avoid cubic or even multiples of dimensions in all but woofers operating over limited bandwidth. Then of course, there's aesthetic considerations - some ratios just look more awkward than others. really, the nanny edited the first 3 letters of assumes
#8 |
What a potty mouth!
haha! Your nanny should spank your little bottom!
I LIKE YOU
#9 | |
there are private forums for those kind of discussions, and this is my work computer, so I'll be on my best behaviour ciao
| uFonken speaker cabinet: Design question | underwurlde | Full Range | 30 | 14th October 2009 04:11 PM |
| question about speaker box design | jaygeorge1979 | Multi-Way | 7 | 12th January 2006 02:33 AM |
| speaker box design physics question | priscared | Car Audio | 4 | 18th November 2005 11:07 PM |
| A couple question regarding speaker design | audioaction | Multi-Way | 2 | 27th January 2004 12:14 AM |
| Speaker Design Question | r.mcnamara | Multi-Way | 7 | 8th December 2002 11:26 PM |
