#11 |
Yes, the mid TL is stuffed until aperiodoc or close to. Its a very useful technique to make low crossovers work predictably. Its something ive been meaning to try for a while
It still amazes me every time I get something right |
#12 | |
Progressive density of the fill and the pronounced taper of the chamber is what we used with the FF85K in Tysen, as well as the MTM with CSS EL166 mid-woofs - it worked out well enough in both cases. IINM the measured curves to which Ryan referred were for the Tysen?
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#13 | ||||
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#14 |
#15 | |
So just build a FAST with a minimum 1st order series x/o. Will solve excursion problems in one stroke. 250 to 400Hz, depending on baffle width, bass driver size. Triangulate the top of the box for the FR, or front to back tube. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#16 | |
like this:?
#17 |
P10, chris, Sreten- Am I correct in thinking that a 1st order series filter is best suited for the OP? In comparison to a parallel 1st order network.
#18 | |
frugal-phile(tm)
dave
#19 |
Yep, series first order XOs are nice in that they compensate for impedance changes, resulting in a flat response again (albeit with the XO point and Q altered slightly).
I'd expect the benefits of taking the LF duties off the smaller driver would outweigh the downsides of a simple XO. Chris |
#20 |
Great! A first order series network it is then, probably at 300 Hz. Do you fellows think that a crossover in that range would detract from vocal intelligibility? I like to hear the lyrics.
| Small Full Range driver selection | Abelma | Full Range | 47 | 24th January 2013 05:26 PM |
| Full range driver in a small speaker system | exeric | Full Range | 18 | 7th April 2012 08:38 PM |
| Small Full Range LousSpeaker with Jordan Driver | scottjr | Full Range | 3 | 4th February 2011 06:37 AM |
| full range low cost and small size driver availability in Mumbai | cutesound | Multi-Way | 1 | 14th October 2006 03:16 PM |
| Help selecting a small Full Range | mimir | Full Range | 9 | 31st August 2005 05:41 AM |
