Prevent Small Full Range Driver From Overextending Itself
Old 16th November 2012, 11:40 PM   #21
harmolodics is offline harmolodics  United States
Originally Posted by chrisb View Post
is there any more info on this design floating around? it looks awesome.
Old 17th November 2012, 12:07 AM   #22
tuxedocivic is offline tuxedocivic  Canada
tuxedocivic's Avatar
I'm not sure a series cross over makes it all that simple... Not having actually done much with series, just thinking here, a series cross over MAY not be as sensitive to the impedance peak, but isn't immune. It's also subject to the woofer filter. Am I missing something here?
I should add, it may work perfectly first order, depending on how things work out. It's just not as simple as making it series makes it work, afaik.
Old 17th November 2012, 12:22 AM   #23
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
True. But XOing in the region where both drivers have minimum impedance seems to be ideal for a 1st order series. There is also lots of room for adjustment by changing the size of the parts... the XO point tracks all the time, but the nature and shape of the hand-over is malleable.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th November 2012, 12:25 AM   #24
frugal-phile(tm)
planet10's Avatar
Not at this time. It is a 1st pass design (but based on work done previously and another example of FASTs to encourage peopel -- if it works you can actually buy the drivers thou), as drawn it doesn't even have the right bass drivers in it (but they are drawn to scale).
The box is the same mT trapezoid as the EL70 fits into and uses the FF85wKeN is all i will say at this time. It is in Chris's queue to build.
dave
Old 17th November 2012, 01:30 AM   #25
norman bates is offline norman bates  United States
norman bates's Avatar
neat
Old 17th November 2012, 01:34 AM   #26
Ben_Tech is offline Ben_Tech  United States
Based on the mention of Tysen, here is the thread from 2009. A thread for Tysen and variations on FAST
Lots of good info there as well for anyone interested in the subject of this thread.
Old 17th November 2012, 10:44 AM   #27
chris661 is offline chris661  United Kingdom
chris661's Avatar
From the thread above, here's the impedance sweep of the 3" driver in free air, and an aperiodic transmission line.
Chris
Old 17th November 2012, 03:32 PM   #28
Thanks Chris. I haven't read through the Tyson thread beyond the first page or so. Probably some good info I need to look at in there.
Old 17th November 2012, 08:45 PM   #29
chrisb is offline chrisb
dave
for which he might need a bass driver in hand to confirm dry fits, particularly of the bracing
Ryan:
did I happen to mention that the very successful MTMs with FF85K was a series XO?
like my mind, this space intentionally blank
Old 18th November 2012, 12:40 AM   #30
Yes I was aware of that and it was single order electrical and I did hear it and it was very good.
Prevent Small Full Range Driver From Overextending ItselfHide this!Advertise here!
Small Full Range driver selection Abelma Full Range 47 24th January 2013 05:26 PM
Full range driver in a small speaker system exeric Full Range 18 7th April 2012 08:38 PM
Small Full Range LousSpeaker with Jordan Driver scottjr Full Range 3 4th February 2011 06:37 AM
full range low cost and small size driver availability in Mumbai cutesound Multi-Way 1 14th October 2006 03:16 PM
Help selecting a small Full Range mimir Full Range 9 31st August 2005 05:41 AM
