Whats a aperiodically-coupled bass-reflex box?
Old 18th November 2012, 10:01 PM   #21
cross reference is offline cross reference  United States
Originally Posted by planet10 View Post
FE126 really needs a horn. If i eas doing an aperiodic box for it, it would reach 150-200Hz.
dave
Well from what the graph he sent me it is flat lined intill 150hz and then dips down. I would be adding a sub woofer at 200hz. So taking care of that problem is solved. The fe126en is flat lined from 150 hz on up. We will see it works? There is a first time for everything right. jm
Old 18th November 2012, 10:57 PM   #22
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Bill Perkins and his speakers...
I actually had the opportunity to buy a pair several years ago and didn't. My loss.
Is Bill still active in loudspeaker design and construction?
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 18th November 2012, 11:04 PM   #23
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Not really,
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th November 2012, 11:05 PM   #24
frugal-phile(tm)
planet10's Avatar
FE126 used as midtweeter like this should be good.
dave
Old 19th November 2012, 01:18 AM   #25
dave
Cool thanks dave. Jm
Old 19th November 2012, 04:16 AM   #26
martino9 is offline martino9  United States
The Dynaco A25 had an aperiodic enclosure that worked very well, particularly given their small size & low cost. Supposedly, they were hand-stuffed to optimize performance.
Old 19th November 2012, 06:02 AM   #27
frugal-phile(tm)
planet10's Avatar
Having parted out dozens of pairs i saw no evidence of hand tweaking,
Some pictures
dave
Old 19th November 2012, 12:40 PM   #28
IG81 is offline IG81  Canada
IG81's Avatar
Has anyone here ever tried the MAPD loading and compared it to a straight-up sealed box or aperiodic enclosure with the same driver? Seems like this is similar to what is done in the Dynaco A35, except for different volume ratios between the chambers.
IG
Old 19th November 2012, 02:59 PM   #29
Some pictures
dave
Wow Dave good to know . I hope I don't have to tweek mine boxes Jm
Old 19th November 2012, 03:02 PM   #30
IG
Sounds like a good idea. I would like to know as well with a side by side testing box types and how they can make or brake a drivers performance. Jm
Whats a aperiodically-coupled bass-reflex box?Hide this!Advertise here!
In Bass reflex box (vented)-If I make smaller box than what consequences will I have? eliaselias_0 Multi-Way 6 3rd January 2011 03:49 PM
Bass reflex box for Beyma 8ag/n bubuxxl Full Range 29 21st October 2010 12:20 PM
whats to be gained from an elaborate box design over a std. bass reflex? demogorgon Multi-Way 11 8th March 2007 05:30 PM
Bass reflex box resonance costin Subwoofers 15 1st May 2006 07:12 PM
Box size for bass reflex DirkD Multi-Way 5 6th October 2004 11:05 AM
