Foam Core Board Speaker Enclosures? - Page 98 - diyAudio
Old 1st January 2013, 02:09 AM   #971
xrk971 is offline xrk971  United States
xrk971's Avatar
Planet10,
Thanks for the impedance calcs. I think the 6 ohms with the 3x8 is probably a good compromise. I wonder if the DTA100 can handle 6 ohms?
Old 1st January 2013, 02:30 AM   #972
Speakerholic
Cal Weldon's Avatar
45 and two rows staggered, what does that work out to?
planet10 needs your help:
Let's help Ruth and Dave
Old 1st January 2013, 02:34 AM   #973
Speakerholic
Cal Weldon's Avatar
If you want some fun with the Cornu, download Bruce Cockburn 'If I had a Rocket Launcher' or Jimmy Buffett 'Pascagoula Run' and turn it up.
Old 1st January 2013, 02:37 AM   #974
xrk971's Avatar
I don't understand the 45 deg? Are you referring to line array? Melo Theory made a 45 deg flooder line array but no stagger.
Old 1st January 2013, 02:46 AM   #975
Speakerholic
Cal Weldon's Avatar
Yes,
The [somewhat] pincushion frame allows you to turn them 45 to align them closer if you choose two rows.
Old 1st January 2013, 02:55 AM   #976
xrk971's Avatar
Ok, that's 48 drivers per channel then, 96 total. I am getting carpel tunnel syndrome just thinking of all the crimping of the connectors! That can get real loud I bet. Have you ever made line arrays? Why do I bother asking a speakerholic, of course you must have! I will have to get that Jimmy Buffet song...
Old 1st January 2013, 03:11 AM   #977
Melo theory's Avatar
Hey Cal,
You like Jimmy Buffet?
I LIKE YOU
Old 1st January 2013, 04:10 AM   #978
Originally Posted by xrk971 View Post
I am out of foam core... the hands are getting restless again not having built something with a razor and hot melt for 2 weeks now. Another run to Dollartree is in order, I might have to buy a whole case of 25 sheets this time like Cal does SWMBO actually said she will pick it up for me if she happens to go by the store!
I have been day dreaming about building a 50 driver line array using a foam core open baffle cabinet with the $1 Aurasound 3 in neodymium full range drivers from Madisound. The drivers are $1 if you buy 50...
Is there a benefit to using foam core for an OB?
What about a BLH line array?
You could arrange it to be a front and back horn. Push-Pull.
I LIKE YOU
Old 1st January 2013, 04:36 AM   #979
xrk971's Avatar
The only benefit is that there is no sawdust and it is light and portable. I was thinking OB because of the extremely high qts of these units. Tell me more about push pull BLH.
Happy new year everyone!
Old 1st January 2013, 04:58 AM   #980
Ok, I just looked at the parameters. Yup, OB.
You could do a push-pull, it would take a bit of eq. But it would be a great experiment, especially with such an easy construction method.
I would have to draw something on the vector program to give an example. I could do that tomorrow.
You will need eq for an OB anyhow, or any type because that driver doesn't have a rising response.
I LIKE YOU
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
Copyright 1999-2017 diyAudio
