Foam Core Board Speaker Enclosures?
Old 29th December 2012, 09:41 PM   #961
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by bcmbob View Post
xrk971, got a link? not sure about "the other thread".
Bob,
Post 188 and 191 in the cornu thread.
http://www.diyaudio.com/forums/full-...ou-can-20.html
Old 30th December 2012, 03:30 PM   #962
makingmoney is offline makingmoney  United States
Default Cardboard box
Cut up a box, taped it tight, dropped in some 3 inch FR drivers hooked it up and it sounds good.
For a free box.
I was thinking about trying out a Cornu spiral out of card board and dropping in these drivers.
Is a 24" or smaller size a safe way to go with these 3" drivers? They aren't too deep maybe 2.5".
Old 30th December 2012, 03:41 PM   #963
bcmbob is offline bcmbob  United States
I thought about cardboard also. But if you find the right "Dollar Store" the $5 investment in foam board for two 24s provides a very stable and strong build.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 30th December 2012, 06:21 PM   #964
Got Foam?
xrk971's Avatar
I second what Bob says.
I used to build with cardboard but find that it is not as stable as it bends in one direction easier than another and the color is just plain objectionable. Having said that, I would not discourage trying it out in cardboard as for the spirals, cardboard nicely bends in one axis and is stiff in other without requiring the scoring with a razor. You can use double layer cardboard for the faces which is stable and strong in both dimensions. In a pinch, you can glue two sheets of single ply cardboard with grain crossed at 90 deg. Let dry and use for face. You will have to cover the cardboard with vinyl contact paper, paint, cloth, etc as the kraft brown color is fugly. Notice how most speaker cone paper is black? They add carbon black to it otherwise it would have the color of brown cardboard and people would ask why they are paying so much money for a cardboard driver .
Really though, if you can locate a Dollar Tree with the 20x30 in foam core boards, buy a dozen or so and you will have lots of speaker building adventures ahead of you.
Those drivers look perfect for trying on this project. What model and size are they?
Good luck!
Old 30th December 2012, 06:37 PM   #965
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
This is my guess:
The Madisound Speaker Store
planet10 needs your help:
Let's help Ruth and Dave
Old 31st December 2012, 11:45 PM   #966
Got Foam?
xrk971's Avatar
I am out of foam core... the hands are getting restless again not having built something with a razor and hot melt for 2 weeks now. Another run to Dollartree is in order, I might have to buy a whole case of 25 sheets this time like Cal does SWMBO actually said she will pick it up for me if she happens to go by the store!
I have been day dreaming about building a 50 driver line array using a foam core open baffle cabinet with the $1 Aurasound 3 in neodymium full range drivers from Madisound. The drivers are $1 if you buy 50...
Old 31st December 2012, 11:51 PM   #967
Speakerholic
Cal Weldon's Avatar
I love your SWMBO. Please mention my name the next time you give her a big hug.
The cases up here are 50 sheets. They are so heavy I can only carry half a box at a time.
Old 1st January 2013, 01:06 AM   #968
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
50 drivers at 82 mm C-C means a 4100 mm line array. You got 14 foot ceilings?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st January 2013, 01:27 AM   #969
Got Foam?
xrk971's Avatar
dave
Actually I have 24 ft ceiling in family room, but I meant 25 per side for 7 footers. They are 16 ohm though, I am not sure how to wire to get 4 or 8 ohm total unless 16 drivers per side.
Old 1st January 2013, 01:48 AM   #970
frugal-phile(tm)
planet10's Avatar
18 drivers: 3 sets in series of 6 in parallel = 8 ohms
20 drivers: 4 sets in series of 5 in parallel = 12.8 ohms
21 drivers: 3 sets in series of 7 in parallel = 6.9 ohms
24 drivers: 3 sets in series of 8 in parallel = 6 ohms
24 drivers: 4 sets in series of 6 in parallel = 10.7 ohms
25 drivers: 5 sets in series of 5 in parallel = 16 ohms
dave
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
