Foam Core Board Speaker Enclosures?
Old 21st December 2012, 07:15 PM   #881
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Ok, leave us hanging on a cliff then....
Old 21st December 2012, 07:26 PM   #882
6L6 is offline 6L6  United States
6L6's Avatar
The horns reenforce the bass in a very nice way, much more than you could ever expect from a 4" driver. Stuffing the chamber and throats is very easy to get the bass in balance with the rest of the driver. Empty isn't all that bad, and too much is really obvious.
Old 21st December 2012, 07:29 PM   #883
Got Foam?
xrk971's Avatar
Congratulations 6L6 on your build!
Photos? Remind me which driver you are using? FF125wk's? Or TB bamboo?
Old 21st December 2012, 08:05 PM   #884
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Cheers.
planet10 needs your help:
Let's help Ruth and Dave
Old 21st December 2012, 09:51 PM   #885
Speakerholic
Cal Weldon's Avatar
ooh, ooh I just got an idea. If I use the table saw as my foam cutting jig it might save me a few minutes building one. I can use the fence as my stopper and the edge of the mitre gauge channel for my cut.
Old 21st December 2012, 10:05 PM   #886
Got Foam?
xrk971's Avatar
Tablesaw without the saw?
Old 21st December 2012, 10:25 PM   #887
bcmbob is offline bcmbob  United States
Sounds like a good technique. You could also use an embedded blade (with proper safety considerations) to hold the blade at 90 degrees. Styrofoam really grabs the blade but tape or glue could also be used. Running this jig against the fence sounds good to me. The same type of blocking can be used to make about six very uniform simultaneous bending cuts in a single stroke.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 21st December 2012, 10:29 PM   #888
6L6's Avatar
I love the idea of the tablesaw fence and one of the channels. Combine that with a T-square to help keep the blade straight and you will (hopefully) be unable to do anything but a straight and square cut.
Old 21st December 2012, 10:33 PM   #889
For those without a table saw a simple $3, 3 foot Alu angle from the local hardware attached to a piece of plywood will work with the block.
Bob M.
Old 21st December 2012, 10:37 PM   #890
6L6 - I believe you used the more expensive drivers. Can you give us a more detailed report of the sound you are getting?
Bob M.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
