Foam Core Board Speaker Enclosures?
Old 15th December 2012, 02:17 AM   #731
Pano is offline Pano  United States
Pano's Avatar
Cool, thanks. Where did you end up on stuffing?
I have 4 slabs of 38"x7' foamcore gathering dust. Might as well put them to good use.
Old 15th December 2012, 02:30 AM   #732
xrk971 is offline xrk971  United States
xrk971's Avatar
Stuffed main driver cavity pretty densely, and loosely stuffed about 2 to 3 inches down the throat of each channel. You have to experiment with this. Surface Tension stuffed the mouths inwards with half of a pillow and got good results that way. According to Cal it makes a big difference how much. I got lucky first time.
Old 15th December 2012, 03:06 AM   #733
6L6 is offline 6L6  United States
6L6's Avatar
Update -
To make a long story short, Liquid Nails is probably not the best adhesive for this - the working time is too short. If they make something similar with a longer working time it would probably be fine.
The perfect thing would be a water-based (or at least water clean-up) construction adhesive with a 20 min working time. I have no idea if such a thing exists.
I may wind up making a third one of these -- at every step the second one is much nicer because I figured out how to do it on the first one... Which is the usual story of DIY.
Then again, I won't know until the glue truly sets and the speaker mounted. It might be fantastic, just a bit rough looking. I'm eager to find out.
Anyway, here is a humorous photo of my 'clamps' - about 60lb (27kg) of paper and cardboard sleeves containing molded petrochemical. It actually worked well.
Old 15th December 2012, 03:17 AM   #734
xrk971's Avatar
The 20 min water based glue might just be Gorilla glue that Cochleus suggested. I have the same picture of books and dumbbells stacked on for a clamp too. It's amazing how much weight that foam can take in straight down compression. You are almost there....
Old 15th December 2012, 03:19 AM   #735
6L6's Avatar
Will look into that - I'm actually researching glues this very minute.
Old 15th December 2012, 03:26 AM   #736
6L6's Avatar
Both these glues fits my stated requirements -- I think I will try the Gorilla.
Gorilla Glue - Wood Glue
http://www.shoplet.com/Scotch-Quick-...i_sku=MMM6052B
Old 15th December 2012, 08:17 AM   #737
bcmbob is offline bcmbob  United States
Let me ask the question another way. I have the TC9FD18-08 but from PE. Are you all suggesting the 20" is closer to optimum for that driver compared to the full 30"?
BTW, Goop has become my go to adhesive for almost all my projects. It grabs and seals almost everything, It comes in a variety of formulas.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 15th December 2012, 10:16 AM   #738
xrk971's Avatar
Bob,
My main reason for making it 20 in was to fit standard foam core sheet sizes, however it is also true that the 30 in size will have a horn tuning freq way too low compared to the vifa's fs of 120 Hz. It may still work but I think the full size is suited for 4 or 5 in drivers.
Old 15th December 2012, 10:48 AM   #739
Thanks, That's much more convent and more efficient with the standard 2 & 4 ft. widths for plywood.
Bob M.
Old 15th December 2012, 11:31 AM   #740
xrk971's Avatar
Bob,
If you are going to use plywood in 2x4 ft sheets, a 24 incher will probably work with the Vifa tc9fd, or a 4 incher like a Tang Band.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 08:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 02:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 09:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 09:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 06:05 AM
