Foam Core Board Speaker Enclosures? - Page 70 - diyAudio
Old 13th December 2012, 09:48 PM   #691
Originally Posted by xrk971 View Post
Yes, I have seen other "Box" speakers wrapped in matching upholstery or drape cloth (glued on with PVA). ...
Good point. You can make the driver "disappear".
Step 1: Cover the front panel with a layer of thick cardboard or thin foamboard, just thick enough so that the driver sits flush or just below the surface. Or, glue a small bead around the front edge so that the covering (next step) is lifted slightly up off the panel, as is done with painters' canvases when mounted on wooden frames.
Step 2: Stretch acoustically transparent cloth (curtain netting, "stocking material", lycra stretch fabric) around the speaker and fasten it (glue, staples) to the back panel. The cloth can be coloured / patterned, or you can paint it with fabric paint.
Old 13th December 2012, 09:50 PM   #692
xrk971 is offline xrk971  United States
xrk971's Avatar
Klampy,
It all depends on how efficient your drivers are vs woofers. If you biamp, you can balance easier. My experience with 2 inch and even 3.5 in FR drivers is that they don't need a tweeter. You need to get drivers with published specs or it can be a lot of time wasted especially for a big wall of sound build.
Old 13th December 2012, 09:53 PM   #693
xrk971's Avatar
Originally Posted by von.ah View Post
No option for DIYing in the foreseeable future. I barely have time to just sit and listen to music on my two home systems. It's all armchair quarterbacking for me currently.
As ST has shown, one who is good with a razor and hot melt glue gun can bang these out in less than 2 hrs. My record is 80 minutes on my second 14 inch spiral. So do what I do and sleep less!
Old 13th December 2012, 10:06 PM   #694
iko is offline iko  Canada
iko's Avatar
Your wife will thank you. Soon she will appreciate the influence diyaudio has on you.
Old 13th December 2012, 10:08 PM   #695
Klampy,
yep, the horn i posted is with drivers i have specs for, i just have to buy them. lol
and bi-amping isnt really an option at this point, altho i really probably should. i have a pair of car amps i could certainly use for this.. its the power supply i might have issues with..... hmmm now you have me thinking...
Old 13th December 2012, 10:17 PM   #696
xrk971's Avatar
I have an old Sony car audio amp, a tiny 25 w per channel but the thd specs are very good. It was in the bottom of my tool box for 15 years sitting there unused until I thought about all the laptop PS bricks I have lying around. I hooked it up to a 19v 4.6 amp brick fom an old Dell. Connected my old Boston Acoustics HD5's plugged in my ipod and wow, that thing seriously is loud and clean without distortion. I think the 25 w was based on 12 volts. Since I am overdriving it with 19 v, probably getting more. You run the risk of frying your electrolytic caps but hey what the heck.... Short story is, use laptop power supplies. They are plenty and cheap. Give the car audio biamping a try. Use car audio active crossovers too. External hard drives use 12 v 2 amp bricks. That will work if you are too timid to try the 19v but cant get much more than 2 to 3 amps for cheap.
Old 13th December 2012, 10:20 PM   #697
see.. this is why DIY is a bad influence... haha.
its a shame i just threw out two LaptopPSUs when i moved house...
Old 13th December 2012, 10:33 PM   #698
xrk971's Avatar
Are you referring to trading sleep for speaker building?
Old 13th December 2012, 10:33 PM   #699
Speakerholic
Cal Weldon's Avatar
I just did a quick calculation of time and materials [incl taxes]:
If I bought everything:
$370
Actually spent for this project:
$150
Hours:
18
Days to complete:
10
Posts in this thread:
137
Satisfaction:
Priceless
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 13th December 2012, 10:41 PM   #700
xrk971's Avatar
Cal,
Thanks For sharing the true cost of your speakerholism
Good thing you had drivers already...
My cost on 20 inch minis
$32 drivers including s/h
$6 for foam boards
$1 gluesticks
Free old pillow stuffing
Free spare speaker wiring ( actually old alarm system 4 conductor cable)
8 hrs time
3 days to complete
But then I did not spend any time decorating it
Cost on 14 inch micros
Free old Logitech s120 drivers and amp
$3 in foam boards
$1 gluesticks
4 hrs time
3 days to build
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 08:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 02:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 09:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 09:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 06:05 AM
Copyright 1999-2017 diyAudio
