Foam Core Board Speaker Enclosures?
Old 13th December 2012, 05:36 PM   #671
bcmbob is offline bcmbob  United States
ST
I have my new Vifa drivers, foam board an plywood - just need a block of time. All the reports are very encouraging. I may have missed the post, but is the router bit you mentioned just for creating the driver mounting hole? Don't see where else it could be used.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 13th December 2012, 05:41 PM   #672
badman is offline badman  United States
badman's Avatar
Anyone wanna sim for Fostex FF85k and Pioneer B20 (Bofu)? Forgive my slackerdom!
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 13th December 2012, 05:56 PM   #673
surface tension is offline surface tension  United States
surface tension's Avatar
bcmbob,
Yes, the router bit is for the driver mounting hole. I just feel like the tighter I can mount the driver the better. The Vifa is very tiny and not a lot of mounting room. I will probably use masonite or thin plywood for the front surface. You can only torque foamcore so much before it shreds or compresses. I get some buzzes at high volume on model one I attribute to poor driver mounting (and possibly inner stuffing needs).
Good luck on your build! Lots of fun.
Old 13th December 2012, 05:57 PM   #674
iko is offline iko  Canada
iko's Avatar
The B20 is the 8in driver right? I asked about using the Visaton B200, also an 8in driver, and the answer was: "it will be huge"
There's no sim for it.
Old 13th December 2012, 06:03 PM   #675
Thanks, I have 1/4" luan plywood (will upgrade if necessary) so should be good.
Bob M.
Old 13th December 2012, 06:05 PM   #676
iko's Avatar
I typed the FF85WK specs into Don's Akabak script and here's the result.
Old 13th December 2012, 06:19 PM   #677
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Glad to hear it's up and running.
In the short term why not glue some small pieces of wood behind your mounting holes for better bite.?
planet10 needs your help:
Let's help Ruth and Dave
Old 13th December 2012, 06:21 PM   #678
Speakerholic
Cal Weldon's Avatar
I creased the strips down on the sharp edge of a kitchen countertop.
I actually used the rounded edge of the countertop, not the sharp edge and formed it much like what happens in a metal rolling machine. The result was a nice compression of the foam at the scores. A nice smooth bend.
Old 13th December 2012, 06:56 PM   #679
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
This is how I did it and it works fine. The foam compresses a little is good - acts as a gasket to seal driver to face.
Old 13th December 2012, 07:19 PM   #680
ruerose is offline ruerose  Canada
phew, 14 pages later....
Was looking for something to put my FR1225S's in. My old 7L towers have outworn the WAF.
Toyed with a PVC Pipe, but getting 6" PVC is not cheap or easy.
I'm surprised no one has thought to vinyl-print some artwork to go on top of the baffle. Probably one of the more decor-flexible designs for speakers I've seen.
Lucky me, I have access to a vinyl print sign making friend.
So my hand is up too.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 08:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 02:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 09:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 09:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 06:05 AM
