Foam Core Board Speaker Enclosures?
Old 12th December 2012, 08:58 PM   #621
Don Hills is offline Don Hills  New Zealand
Originally Posted by ikoflexer View Post
My prediction is that the measurement will not look like the simulation, with all due respect for Don's skills. I think the simulation might be oversimplified.
The simulation assumes perfect horns. If you unrolled the horns so they were straight, and used no stuffing, you'd get physical results closer to the simulation. The folds introduce a HF loss, and Cal found stuffing is required to damp the resonances predicted by the model... Note also that I recommended restricting the frequency response display in the simulation to a maximum of 1 KHz, to avoid being distracted by higher-order resonances that would be much smaller in reality.
Making the model more accurate means it gets complex very quickly. It's like predicting the weather - the more accurate you want the prediction, the more factors you have to include in the model.
Old 12th December 2012, 09:32 PM   #622
Originally Posted by xrk971 View Post
Don Hills,
I like your reverse spiral horn clock radio. I think the old Bose gen 1 had only a serpentine path on 1 driver and they went to 2 on later generations exiting a single common port like Klampy's. Are you thinking 2 in drivers or 3 inchers? The TB W3 881si for $10 ea comes to mind.... The led's with auto mosfet is a really good idea too. Do you have a schematic for that? I just had a thought, if the spirals are relatively thin, stack two one fires up and the other down, or they could both fire to common down port?
Xrk971
I've only seen the Gen 1 internals. Driver choice would depend on how big you wanted to make it - small drivers with low Vas / Qts would allow making it smaller.
No, I don't have a schematic, but it's not hard - all I need is to get a round tuit.
An enclosure with two spirals would be twice the volume of that with a single spiral, and would be complex to build. It needs some thought...
Old 12th December 2012, 11:19 PM   #623
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Originally Posted by adason View Post
maybe it would sound the same in the box of the same size
Nope.
(Cal - do you have means to do a measurement?)
Nope.
The spiral definitely has a PROFOUND effect
Yup.
When I place my ears next to the output horns on the edges...
...A surprising amount of horn output is noted.
I got bunch of really good sounding 4" fullrange speakers
hehe, looks like we have another in the fold.
Adason, there's no hiding my speaker addiction as you guys are all aware but this has offered a number of things that I have not had before in speaker building. You will realize this when yours are done.
Cheers.
planet10 needs your help:
Let's help Ruth and Dave
Old 12th December 2012, 11:23 PM   #624
Speakerholic
Cal Weldon's Avatar
Without stuffing, it sounds bloody awful. With too much, it sounds like a regular FR in a box. Get it just right and something begins to get all fuzzy in your insides.
Old 12th December 2012, 11:35 PM   #625
xrk971 is offline xrk971  United States
xrk971's Avatar
Two spirals would just double the thickness or add about 2.5 in in height.
Old 12th December 2012, 11:41 PM   #626
xrk971's Avatar
It's a fine line between not enough and too much stuffing. I got lucky but wonder if it would be worth playing around with. You are right describing it as getting fuzzy inside. I actually have found a renewed interest in listening to music because some songs sound so much better than I knew they could sound. Almost a rediscovery of certain songs for me which did not grab me and make me feel fuzzy inside before. I hope you are enjoying yours properly hung up on the wall now. Or is it stands?
Old 13th December 2012, 12:41 AM   #627
Speakerholic
Cal Weldon's Avatar
In case I didn't make myself clear about the advantages:
1. Fast
2. Cheap
3. Easy
4. Highly gratifying
5. Done two at a time
properly hung
That doesn't hurt.
Any questions?
Old 13th December 2012, 12:44 AM   #628
xrk971's Avatar
You forgot number 6: high WAF if properly hung, on wall that is....
Old 13th December 2012, 12:47 AM   #629
xrk971's Avatar
Wow, I just noticed that thread broke 20k views!
Old 13th December 2012, 12:48 AM   #630
6L6 is offline 6L6  United States
6L6's Avatar
So what you are saying is that they are fast, cheap, and easy, but it helps if somebody is well hung? LOL.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 08:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 02:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 09:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 09:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 06:05 AM
