Old 8th December 2012, 01:09 AM   #501
xrk971 is offline xrk971  United States
xrk971's Avatar
Originally Posted by Cal Weldon View Post
Pics:
I see there is still a little glue string and a grill cloth tuck needed in the middle pick. Oops.
Wow! Very nice looking. The oil turned out very nice and adding the trim frame with fabric really makes it look polished and professional looking. Congratulations on being done!
Now relax and enjoy the sound!
Old 8th December 2012, 01:14 AM   #502
Speakerholic
Cal Weldon's Avatar
Originally Posted by xrk971 View Post
Cal,
Thanks for the minute play by play with your adjustments.
Except for the fact that my dinner is getting cold, I am happy too.
Are you using a spectrum analyzer? Even software one using the computer mic is helpful.
WTF is a spectrum analyzer? Sounds like something that should be left to a doctor.
Software is what my wife calls me when I can't...umm...you know.
I am listening to mine now and think that I must have just gotten lucky with the light stuffing i put in the throat.
I will experiment over the next few days, but at this point we are good, not great, but really, really good good.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 8th December 2012, 01:15 AM   #503
Speakerholic
Cal Weldon's Avatar
Thank you. I have enjoyed the journey.
OK, those are instructions I can follow.
Old 8th December 2012, 01:27 AM   #504
made me LOL
Old 8th December 2012, 01:37 AM   #505
6L6 is offline 6L6  United States
6L6's Avatar
Cal - those look great!
How far did you jam the stuffing in the throat? Was it getting really tight or still kind of loose?
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 8th December 2012, 02:05 AM   #506
Speakerholic
Cal Weldon's Avatar
Tight, that's what leads me to believe is was getting close to aperiodic.
Old 8th December 2012, 02:10 AM   #507
xrk971's Avatar
That's hilarious. Not sure if you are sharing too much there Cal
I use FrequenSee for the spectrum analyzer, works on Android phone or tablet. There is probably a pc version, but gives you instantaneous real time graph of sound pressure (arbitrary units) vs frequency. Pretty handy for checking speaker response.
https://play.google.com/store/apps/d...equenSee&hl=en
Old 8th December 2012, 02:14 AM   #508
xrk971's Avatar
Do you mean bass is tight or stuffing is tight? When you say aperiodic, you mean there is no resonance peak?
Old 8th December 2012, 02:24 AM   #509
Speakerholic
Cal Weldon's Avatar
Oh god, all these questions...
Tight meant both. There was too much insulation in the throats so the bass was literally sucked out. With it removed there is the 200 peak again but not too bad. I am guessing that a light stuffing might do the trick.
Old 8th December 2012, 04:13 AM   #510
... How do you model the split lengths?
Like this:
Code:
                     Throat              +-- Horn 2 -- Radiator
Radiator --Driver -- Chamber -- Horn 1 --+
                                         +---- Horn 3 ---- Radiator
... Do you mind scaling it to 20 in (50 cm) and running it with the Vifa tc9fd ...
See attached. I assumed 6 cm depth. It doesn't look good... I think the volume (depth) is too small and the horn is tuned too low.
... Also, at the 70 cm, the longest path should get down to about 38 Hz, the sim shows falloff below 50 Hz. ...
It is what it is. The impedance and excursion graphs (of the 70x70 cm model) show resonances at 61 and 119 Hz. I suspect the bifurcated horn is the problem. The longer of the two "output" horns is 138 cm, which is 1/4 wavelength at 62 Hz. That's why I want to re-sim with equal length horns.
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 7 25th July 2010 01:32 PM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Speaker damping: Foam or expanding foam akunec Multi-Way 2 16th September 2005 06:26 PM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
Copyright ©1999-2013 diyAudio
