Foam Core Board Speaker Enclosures?
Old 5th December 2012, 11:15 PM   #411
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by cogitech View Post
Thanks to Cal for turning me on to this thread.
What's the concensus on EL70 drivers for this project?
I have seen some not-so-favourable mention in recent posts regarding the prospect of using EL70s, but xrk initially thought they might be a good candidate.
Has anyone tried it?
I think I said CHR70, but these look good too. I think the Cornu is very tolerant of different drivers.
Old 6th December 2012, 12:01 AM   #412
cogitech is offline cogitech  Canada
cogitech's Avatar
Thanks for the reply. Would you be so good as to have a look at the T/S numbers of the EL70s and let me know what dimensions would be ideal for them?
Old 6th December 2012, 12:27 AM   #413
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I am happy with the appearance for something called underlay. Last pic shows the piece I added for strength. In that pic you can see the oil contamination on the edge that I now have to deal with
Bad Cal!
planet10 needs your help:
Let's help Ruth and Dave
Old 6th December 2012, 12:43 AM   #414
Speakerholic
Cal Weldon's Avatar
I think so too.
Old 6th December 2012, 12:54 AM   #415
Got Foam?
xrk971's Avatar
All I do is scale the channel depth so that the throat area is at least as big as the driver piston area Sd. For the EL70 follow the 70 x70 cm plan and make it 3.9 in deep (4 in is probably ok). One thing that concerns me with these drivers is that they don't have a rising high end like TB W4-1337 which looks like a tweeter from 10k to 20k Hz. The Cornu puts out so much bass it can really benefit from an 'unaturally' high end to get decent highs to compete with thr bass. Usually you have the other problem, not enough bass. Also, if you don't need the horn to reach down to 38 Hz you can scale it smaller, the low bass tuning freq scales proportionally.
Old 6th December 2012, 12:56 AM   #416
Got Foam?
xrk971's Avatar
Bad Cal!
Good idea to put the wooden handles there. Looking good Cal!
Old 6th December 2012, 01:09 AM   #417
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
EL70 is smaller than FF125.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th December 2012, 01:13 AM   #418
Got Foam?
xrk971's Avatar
dave
Yes, that's why channel depth on FF125 was 4.5 inch and 3.9 inch for EL70.
Old 6th December 2012, 01:42 AM   #419
iko is offline iko  Canada
iko's Avatar
Bad Cal!
Too bad about the oil spill Cal!
Quick question for you, since you have the same plywood as I. Do you have any idea what the top veneer is? Does it look good with the oil on? I'm not sure whether to go for shellac or simply do it with oil like you.
Old 6th December 2012, 01:50 AM   #420
iko's Avatar
What do you expect they are, afterall, Dell Boxes
Don't forget that you want to get at last 100 hrs on them before paying much attention to what they sound like.
dave
Thanks guys! Funny thing is, I had some old 5" mid/base drivers from an old Kenwood stereo and put them in the big Dell cardboard boxes in parallel with the vifas. It completely floored me: full nice bass and mids, and there are highs too. The cardboard boxes beat my other speakers. The cornucopya has to be better, I can't keep the cardboard in the living room.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
