Foam Core Board Speaker Enclosures?
Old 4th December 2012, 01:15 AM   #371
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Cal and I discussed using bolts with tubes where speaker screws are.
Rather than dowels.
Old 4th December 2012, 02:05 AM   #372
6L6 is offline 6L6  United States
6L6's Avatar
Rather than dowels.
Ooh! That's a great idea! I never thought about that part, other than using through bolts and fender washers on the back. The tube is a great idea.
The dowels I'm envisioning near the end of the horns... to brace where the outer panels are furthest from the foamcore.
Old 4th December 2012, 02:53 AM   #373
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
with tubes
I have been collecting the corrugated plastic spindles from cash receipt printers (Dalis the girl at the post office does the actual collecting). Some of them are long enuff to be perfect for this.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th December 2012, 03:05 AM   #374
Got Foam?
xrk971's Avatar
Old plastic pen tubes could work too. Need snug fit or it rattles. Plumbers putty stuffed inside tube will also do the trick.
Old 4th December 2012, 03:28 AM   #375
sandyhooker is offline sandyhooker  United States
sandyhooker's Avatar
Smile Artt Supply??
Originally Posted by 6L6 View Post
Sandy- any art supply house will have the board, as well as reprographics houses and maybe even Walgreens . The stuff from the dollar store is really inexpensive. I did get one sheet 24x36 of 'good' foam core for the exposed bits.
I'm 100 hundred miles away form such luxury. I knew it was a mistake moving to the Desert . Somehow, I will prevail.....
Old 4th December 2012, 09:30 AM   #376
Got Foam?
xrk971's Avatar
You can order them and have it in a few days. I have ordered boxes from this company before. They seem to have a wide variety of sizes at a reasonable price.
Foam Board, Foam Core in Stock - ULINE
Old 4th December 2012, 10:41 AM   #377
Doug R is offline Doug R  United States
Another source for plastic tubes is those used for nails/screws to hang gutters. HD, Lowe's, etc. will have them in the gutter dept. - and cheap.
Doug
Old 4th December 2012, 01:24 PM   #378
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Ferrules, I never though of that. Pretty dumb for a guy in the roofing business, no?
planet10 needs your help:
Let's help Ruth and Dave
Old 4th December 2012, 10:10 PM   #379
Got Foam?
xrk971's Avatar
Is anyone building the smaller 20 inch version, or all you all going for the full size 70 cm or larger? Just wanted to have some comparisons from others for my build with tc9fd's.
Old 4th December 2012, 10:28 PM   #380
iko is offline iko  Canada
iko's Avatar
I got a pair of TB W4-1320 and a pair of tc9fd's on the way. I might do the minis too after the mediums are done.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
