Foam Core Board Speaker Enclosures?
Old 15th May 2018, 11:47 AM   #3001
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by picowallspeaker View Post
It doesn't have to sound at all, no matter of which material or construction method
Well, sound of the native material is important. It has been proven on 3 builds that the mini Karlsonator sounds better when made of foam core or XPS foam and not plywood or MDF. Everyone who made it from plywood complained of a boxy sound. Switching to foam core made it an excellent sounding speaker, unlinstenable as plywood.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 15th May 2018, 03:12 PM   #3002
hoyungh is offline hoyungh
X i am not sure if this makes sense but when the foamcore is braced well the surface is taut like a drum and does feel like one so on playing drums the whole speaker sounds like a drum. on real drums the size determines the resonant frequency but on this speakers all drums sound natural. when not braced well it still sounds ok at low volume but as the volume goes up the sound is off(like loose or flabby?)
Old 15th May 2018, 04:32 PM   #3003
Jennifer G is offline Jennifer G  United States
I really like the idea of the pink foam.. because I like art deco and well I can put a few progressively smaller layers of the thinner foam on the sides I can cut to any shape I like
Q: The tweeter is supposed to sit just under the tip of the woofer.. is that necessary or can I have a small gap between them? Recessing placing under the woofer is more difficult.
Old 15th May 2018, 05:18 PM   #3004
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Originally Posted by Cal Weldon View Post
In the back of the pic, with the help of some cutting boards, a food processor and a vacuum sealer are assisting with the last of the glueing.
Cutting boards? Check.
Vacuum sealer? Check.
Food processor, hmm...
food processor...
A food processor?
Is that for the margaritas?
Tim
Old 15th May 2018, 06:15 PM   #3005
Got Foam?
xrk971's Avatar
I am more concerned about rattle, or excessive movement which leads to distortion as it is in phase with sound from driver.
Old 15th May 2018, 09:43 PM   #3006
for karlson clones below upper tuning its fine because the front and rear are the same(in phase)? but above tuning speakers act like dipole? but when i walk around speakers there is still huge sweet spot in front and there doesnt appear to be a place where the sound dips or changes character or volume as i move to the back. maybe its because my ears are failing
Old 15th May 2018, 09:53 PM   #3007
DMLBES is offline DMLBES
There are two types of foam....EPS=Expanded Polystyrene (usually white color) and XPS=Extruded Polystyrene (usually either pink or blue color).
Also there are different degrees of densities/grades for each type of Polystyrene, which range from very hard/stiff to very soft/flexible as this will effect the sound of the enclosure.
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
